substitue clay lube?
a4portree Oct 21, 2011
  1. a4portree
    a4portree New Member
    Hi Guys
    any ideas on a substitute for clay lube? i have ran out mid claying through my car!! i know i know i should have checked how much i had but i have ran out!!
    also i live on the isle of skye and running to the nearest auto shop is 2 hours away!!!
    any hel;p much appreciated
  2. gavsman
    gavsman Member
    379
    you could use Car shampoo & water mix in spray bottle, then for next time get yourself the Bilthamber clay bar ( as you only need to use water with it!)
  3. a4portree
    thank you!!!!
  4. a4portree
    i can pm you as i dont have enough posts, i have 18" rs6 reps for sale all 5. pm me if you ant more info. or pm me your number and ill give you a ring
  5. John @ PB
    John @ PB Member
    360
    Don't use a shampoo solution; it can degrade your clay bar. I've seen this done and bits of clay fall off; clay's abrasive and you'll end up marring the surface.
    If you don't have any dedicated clay lube, use plain warm water and work carefully. Keep the clay in plenty of hot water too to keep it supple.
