  1. bouncer117
    bouncer117 Member
    307
    Are all b5 subframes the same?
    Just noticed a large rust hole whilst removing the steering rack
    Sent from my D6603 using Tapatalk
    Browett1982 likes this.
  2. aragorn
    18,577
    868
    there are differences between 4 cylinder and v6 ones.
    The v6 one fits the 4 cylinder car but you need the V6 nearside gearbox mount as well. Not tried the other way round.
  3. bouncer117
    bouncer117 Member
    307
    I have 2.8 would 2.5 be the same then
  4. bouncer117
    bouncer117 Member
    307
    How easy/hard is it to remove the subframe?
  5. aragorn
    18,577
    868
    2.5 should be the same.
    Support engine and trans from above. Remove lower control arms. Detatch engine mounts. Unbolt frame and drop it out.
    bouncer117 likes this.
  6. bouncer117
    bouncer117 Member
    307
    Is the a6 97 - 01 v6 subframe the same? They look very similar
  7. aragorn
    18,577
    868
    yep should be, the A6 uses the outer set of holes, the A4 uses the inner set where the control arms mount.
  8. bouncer117
    bouncer117 Member
    307
    A4 subframes are around 100-150 a6 are around 50-100 if they are the same that makes me happy
  9. aragorn
    18,577
    868
    folk really charging that much? thats mental for a bit of pressed steel thats littering scrapyards.
    I didnt even bother taking mine off the last B5 i scrapped.
  10. Phil_R
    Phil_R Member
    31
    10
    There looks to be two different styles of subframe, not just in the transmission mountings, I paid £25 delivered for an A6 V6 subframe so it was easier to fit the V8, the top subframe is the original and the A6 V6 subframe is different on the front crossbar it is lower and gives more clearance for the sump. I have also seen this style listed as an A4 subframe.
    Putting a level across the front mountings and measuring to the crossbar showed the difference in clearance
    A6 V8 Subframe - 98mm
    A4 1.8T (top in picture) - 86mm
    A6 V6 (bottom in picture) - 105mm
  11. aragorn
    18,577
    868
    yeh the v6 frames have more clearance around the sump, and different gearbox mountings for the nearside exhaust. A6 and A4 V6 frames are the same part number.
    Annoyingly, the A6 V8 frame only has the outer A6 holes, they didnt bother drilling the inner ones for the A4 fitment on the V8 frames :(
