Subaru ECU Repair
Welly Nov 8, 2009
  1. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    Unusual question on an Audi forum I know, but does anyone know a good ECU repair place that has the facility to repair Subaru ECUs...
    Obviously I've googled this - but no-one seems to repair Scooby ECUs!
    Any help appreciated or ideas appreciated. :o.k:
  2. jojo
    28,993
    3,638
    not 100% sure, but I don't think they are linked to the immobiliser like the Audi ones are. You could probably just get a used unit and swap over?
  3. Broken Byzan
    13,237
    465
    what about BMA reman, or whatever they are called, they do all of them iirc
  4. Welly
    10,696
    130
    Let me give you a little background on this one then.
    The ECU has some sort of fault with measuring voltage produces by the Altenator. Basically, as long as you leave the fan on level 1, the EML stays off. However as soon as you turn it off, the EML comes on and it needs to be reset by a garage.
    It's obvious by this that the ECU deems that there is too much current being produced by the altenator, and the fans drains that extra voltage off.
    Altenator has been tested, and is outputting correctly, and it's been to Subaru who agree that it's the ECU at fault. They wanted to supply another at £1200 (it's a pro drive one) which is a bit steep!!
    Anyway, so wanted to know if anyone knew a place that could test/fix it...
  5. Welly
    10,696
    130
    Byzan, do you mean BBA Reman? Just has a look at their site and that's definately worth a look. I'll bell them up tomorrow :thumbsup:
    You had any experience with them? Good/Bad?
  6. Broken Byzan
    13,237
    465
    Thats em, yeah, they do ABS pumps and all. Plenty of the B5 guys have had ABS pumps done with good results.
    Same for dashes, had the DIS panels fixed
  7. Welly
    10,696
    130
    Coolio, will defo ring them tomorrow, thanks dude. :beerchug:
