Stupid question! Removing number plate?
audi58 Apr 18, 2010
  1. audi58
    audi58 Member
    134
    Hello, just ordered a personalised plate, could someone please tell me how to get the old ones off? There are no screws? Once off, do I need to re-glue the new ones on or what?? Thanks
  2. Wai-Fan
    Wai-Fan Member
    530
    Just slowly yank them off and then remove the old bits of glue, fixing tape etc off. Give the area a good clean and attach the new plates back on with some new fixing tape etc etc. Also if it's really difficult to remove, then you could try applying some heat, like using a hair dryer or something.
  3. mdre83
    mdre83 Member
    634
  4. Sarah's A3
    Sarah's A3 MODERATOR V6 S3 Hybrid Staff Member Moderator
    5,920
    30
    Erm, pull off and either use pads to stick the new plates on or screw them on
  5. scottie123
    scottie123 (●̮̮̃•̃) (●&#
    1,972
    I tried the tesa strips to hold my plate on. But it was hanging off the next morning.
    I bit the bullet and screwed the fecker on
  6. Staz
    Staz is a retronaut Staff Member Moderator VCDS Map User
    6,206
    64
    Really?! I'm not sure what went wrong there mate but I have used them about 10 times for fitting plates and they're always stuck solid! You do need to push on them for a couple of minutes to get them to really stick I guess.
  7. scottie123
    1,972
    The back one stuck like poop to a blanket with the strips.
    I Thought it had stuck fine on the front also, but I found yesterday morning that my plate has started to come off already. Perhaps it is due to the curvature of the front mount, and my sloppiness of not bending the plate first to help it out.
  8. Staz
    6,206
    64
    Yeah now you've said that I remember I did have to spend a bit longer on the front one. I think I may have ended up using 4 of them too. Sorry mate.
  9. audi58
    audi58 Member
    134
    Thanks guys!
    does anyone know how long it takes once you get the Reg Certificate through? I think i've got to go to a DVLA office! Lovely :think:
  10. scottie123
    1,972
    Should be able to do it in under a week. You will recieve your v750 fairly quickly. Take that as proof and get a plate made. Go to local dvla with you mot and v5. Say thank you and go put your plate on the car. oh, and let your insurance know aswell:)
  11. waqi
    waqi Member
    150
    Take it to a DVLA centre when it isn't busy and you should walk out with all your new documents within minutes! You can post the documents but then you gotta wait weeeeeeeeeeeeeeeks :icon_thumright:
  12. audi58
    audi58 Member
    134
    oh yeah, insurance! Can't forget that, thanks for all the advice scottie! :happy:
  13. scottie123
    1,972
    Dont fret Staz! I used 8 of the strips on the front LMFAO! They would have probably worked better If the tool applying them did it properly :icon_thumright:
  14. PH1L
    PH1L Gievf Buckets
    3,851
    40
    i use 3m double sided to stick my metal plates down, does the trick, the red variety not the green, expensive but worth it in the long run
  15. Staz
    6,206
    64
    EIGHT?! That's supposed to hold 8kg!! lol
  16. scottie123
    1,972
    My plates must be extra heavy :)
    Perhaps I misread when ordering and got the iridium ones (worlds heaviest metal )
    :jump:
  17. Staz
    6,206
    64
    LOL
