stupid question, Re. aircon
chris_20 Jun 19, 2007
  1. chris_20
    chris_20 Member
    707
    guys when i put the climate control down to 'Lo' does this mean that i have engaged the air con?? just that im not sure how to turn the air con on. i think it may need re-gassing as it just blows out warm air but i want to make sure that when its on 'Lo' that this is the air con.
    sorry if its a silly question but just to save any confusion/embarressment before i call the air con guys.
    cheers folks
  2. simonwjones
    simonwjones Member
    365
    Yes thats all you do. BUT if the ECON button is pressed and lit, it will turn off the compressor and so wont blow cold
    Simon
  3. golf
    golf ***** rent boy VCDS Map User
    1,556
    Like Simon said (anyone remember that game?), just make sure the ECON button is not lit up as this will not engage the compressor, and you wont get your lovely icey breeze.
    It more than likely will probably need regassing. It's around £45 from places like Kwik Fit, so it's not too bad.
  4. simonwjones
    simonwjones Member
    365
    If you want cold air dont press the ECON button
    Simon says " If you want cold air, dont press the ECON Button"
    Which one is correct?
    Simon says
  5. shineydave
    shineydave Member
    920
    if the light on the econ button is lit up then aircon is turned off. you want the econ light off and the auto light on then relax in the airconditioned comfort
  6. AndyMac
    9,832
    45
    aircon is always on with climate control, unless you press the ECON button.
  7. chris_20
    chris_20 Member
    707
    cheers boys, didnt know kwik fit done the regassing. how long does the process take, could it be done in dinner hour for example?
  8. golf
    1,556
  9. Shades
    Shades Member
    588
    Doesn't setting the temp to 'LO' automatically switch the 'ECON' button off if it is on?
  10. A4 TC
    A4 TC 1.8T quattro sline
    211
    10
    Just had me car serviced at audi today, They rang me up about an hour after dropping car of and say would you like to re-charge your air conditioning, as it it is recommended after every 2 years it needs re-charging and it costs £122 +vat, Im glad I declined this as you say £45 to re-charge air con is better than £122+vat.
  11. chris_20
    chris_20 Member
    707
    cheers golf. great help as always mate
  12. Rocko
    Rocko A5 TSFI
    534
    Kwik-fit regassing takes about 1 hour. They suck all the gas out first, do a vacuum test, then regas.
    If you haggle you might get it for £24.99, as they had it on their website briefly as that.
    My mates a kwik fit fitter and hes the one to trust. (Oh god)
