Stupid eBay sellers
voteforpedro Jun 18, 2009
  1. voteforpedro
    voteforpedro Member
    632
    So I bought this short shifter kit:
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=130298901701
    The listing says 1996-2003... the box said 2001-2003...
    So after ripping my current shifter apart, imagine by disappointment to find a number of differences and problems...
    - Short shifter has a bend; stock shifter is straight
    - Short shifter uses push-on knob; stock is screw-on
    - Supplied bolt to attach stick to joint does not fit through the drilled holes in one side of the joint
    - NO INSTRUCTIONS
    - Came with loads of plastic bits not present in the stock shifter
    - Stock plastic "ball" has a large plastic bit which touches plastic dampers to stop it from clunking; not transferable to the new shifter
    After dismantling the old one and loosing the springs which fly everywhere I somehow managed to find them and reassemble the old shifter although my Redneck circlip installation technique means I will have to sort it out pretty soon.
    I am not happy. Can anybody recommend a short shifter that WILL fit my car and which DOES come with instructions?
  2. docurley
    4,071
    85
    I think you will find he sent you the wrong one by mistake as he sells lots of different types, email him and ask him to change it.
  3. voteforpedro
    voteforpedro Member
    632
    tbh I don't have much faith in sellers who assume which car I have and don't think to ask. I would rather get a refund and go elsewhere.
  4. docurley
    4,071
    85
    I would give him one chance to fix the issue, people make mistakes.
  5. Broken Byzan
    13,237
    465
    The pic is of the same kit i used to fit my old B5 5 speed. Do you have a pic of the new setup> maybe it's comat with my 6 speed and we can do a deal and all be happy?
  6. voteforpedro
    voteforpedro Member
    632
    The pic looks like the correct one but the one I received is not - the stick is bent and not threaded at the end for the knob and there are other differences.
  7. Oranoco
    Oranoco Well-Known Member
    3,952
    402
    The link looks the same as the kit I got.
    Got mine off a mate for £10 as he said it was missing a couple of bits. My brother was going to knock up some replacements. Was well chuffed when it turned out to be complete. lol
  8. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,772
    32
    A push on top is from the B6 I think. Send it back, i'm sure he'll sort you a replacement.
  9. Oranoco
    3,952
    402
    ^ What he said. We're only human and mistakes happen. Give them the chance to rectify the mistake
