stumped on this one
bigal23 Apr 8, 2013
  1. bigal23
    bigal23 Member
    206
    on my a3 140 the anti-shudder valve had stopped working which is a common fault so I replaced the part and its working
    but I still get a horrid shudder on shut down. now this happens 98% of the time only maybe 4-5 times its not made a shudder on shut down I have taken it two darkside and they carnt figure out why its doing it and neither can I. I have replaced fuel filter cleaned inlet manifold out replace seals checked its working on shut down everything I could think of do you guys have any ideas as me and darkside have no idea what to do with it
  2. Bramley
    Bramley Member
    389
    19
    fuel pump??
  3. bigal23
    bigal23 Member
    206
    why would or could fuel pump cause this?
  4. Geraldy212
    Geraldy212 Sportback owner
    565
    42
    Bigal, are you 100% sure that your new anti-shudder valve is working properly? If it really cuts off the air, the engine should stop immediately. The only reason not to stop is if there is a source of oil getting into the intake manifold. Hope this is not that case, but I would certainly check the valve again.
  5. TDI140
    TDI140 Well-Known Member
    1,624
    174
    Was the oart brand new or did u buy second hand if its second hand u need to buy a new part as they made a different part number as the old ones were faulty so the new one has been strengthened
  6. bigal23
    bigal23 Member
    206
    brand new from eurocarparts with a nice 30% discount.
    its working I popped the pipe off and looked in when I switch the engine off and it closes for about 2-3secs then opens.
    don't see how oil could get in had everything checked over no oil in fuel or anything.
    all I could think when I watched it close was is it closing quick enough? could it close to slow and leave you with the shudder
  7. bigal23
    bigal23 Member
    206
  8. Geraldy212
    565
    42
    Bigal, you are right to worry about ASV closure speed. As far as I know, the flap is spring-loaded to stay open, and the motor has to force it to close on switch off. Any unnecessary friction or low voltage, or bad contact may indeed cause it to close too slowly. If you can find another BKD engine to look at, you might be allowed to pull off the pipe and compare. When a diesel is told to stop by having its fuel injectors shut-off, it will try to scavenge any oil (or fuel) it can find from the whole intake system, and therefore try to run-on. If by chance the intake system is contaminated by oil residue, or oil leaks from the turbo, then this oil will be happily sucked into the engine on switch-off. Causing a slight run-on if the ASV does not do its job well, or perhaps quickly enough. Good luck.
  9. bigal23
    bigal23 Member
    206
    could this be the battery not supplying enough voltage? I have tested the battery with a multimeter and all is good but when I turn the car on and the radio or mp3 is on and lights it all cuts out for a second the other days I do the same and nothing cuts out at all
  10. Geraldy212
    565
    42
    Trot around to your nearest auto battery shop or local garage and ask them to test the battery with a load-tester. That should give you a good indication of the general health of the battery. It is a worry though if there is an electrical cut out at any time. Get the shop to check on battery terminals and grounding points for corrosion, and possible loose fuse(s)/holders too.
  11. TDI140
    1,624
    174
  12. bigal23
    bigal23 Member
    206
    the asv works fine and is not faulty car battery is good connections are all clean.
    tdi140 I plugged the car in to a friends vcds and I have two faults one is egr as I have deleted it but not mapped it out and the other a glow plug 3 fault, there is a couple of others but there to do with the fact I have xenons but without the auto levelling s come up with two faults for that.
    am lost with, I did have one idea could the injectors be leaking slightly and its running on from this slight leak?
