Stuck radio 8L S3
Speedy Steve Jun 15, 2010
  1. Speedy Steve
    Speedy Steve Active Member
    1,258
    I have an 8L s3 with a double din radio and its stuck the keys don seam to touch anything when putting them in. Now the radio has stopped working altogether fuses around the car look fine so i take it that there is one on the back of the head unit but i cant get it out. Im starting to feel like just ripping the face off the head unit and get it out that way then fit a normal double din unit and make up the sides. Is there an easy way of getting the old unit out with out the destruction?
  2. AndyMac
    9,832
    45
    Not really because you've probably been trying to pull it out by pulling on the release keys. You need to insert the release keys and then push the HU from behind by removing the glovebox. No idea why they sell the keys with lugs on them for pulling as this will knacker the spring clips if they aren't perfectly locked in place.
    The clips will now be jammed. You'll just have to use brute force by pushing from behind
  3. Speedy Steve
    1,258
    Ok thanks Andy i will give that a try
  4. Speedy Steve
    1,258
    Managed to get it out and the fuse had blown i still have the problem that the radio will only power up if you switch it on not through the ignition
  5. AndyMac
    9,832
    45
    That means it's not getting an "ignition on" 12v when the ignition is on. Have you checked the Radio (S-Kont) fuse in the fuse box? IIRC it's fuse 30, as there are 2 fuses for the radio (perm live and ignition). Failing that check the yellow cable with red stripe on the black power ISO connector at the HU. This should be providing 12v with the ignition on and 0v when you take the keys out.
  6. Speedy Steve
    1,258
    Ah never knew there was 2 fuses for the radio that may well be it Andy thanks will be checking that later this week when i next get a chance
  7. Speedy Steve
    1,258
    Andy you are a star its fuse 37 (S contact) had blown took out one of my other fuses as had no spares and it worked properly
  8. AndyMac
    9,832
    45
    Nice one, my faith is restored and sometimes it really is just the fuse and nothing more sinister!
  9. Speedy Steve
    1,258
    Thanks again have just ordered some adaptor rings off you through the mighty Bay
