Strut Braces & 4motions
Yohan87 Oct 30, 2012
  1. Yohan87
    Yohan87 Guest
    I have a Bora 4motion with the following handling upgrades: -
    H&R V1 Twin Tube Coilovers
    S3 Cast Wishbones
    Every bush replaced with Superpro/Powerflex bushes
    R32 Front ARB
    Neuspeed Rear ARB
    1x Pair of Forge Adjustable Tie Arms (Upper)
    I think the car handles very well, it sits very flat round corners and is also surprisingly comfortable considering the modifications.
    I know the S3 8L comes with a lower strut brace as standard but the Bora 4motion does not.
    Would front (upper/lower) or rear strut braces contribute anything to this setup? The car is used as a daily but I would like to attend the odd track day when I get the time.
  2. Andrew@A.L.D
    3,879
    617
    The upper strut would help but the lower one doesn't really do anything, yes you could make a lower strut brace which i did and couldn't really tell but as soon as i fitted some solid sub frame bushes then you could feel the front end stiffen up and make the steering a little sharper
    034 Motorsport Audi 8L/VW MK4 front soild subframe bushings
  3. Dani_B19
    9,382
    403
  4. Andrew@A.L.D
    3,879
    617
  5. Dani_B19
    9,382
    403
    Why you say that mate?
  6. Andrew@A.L.D
    3,879
    617
    Your sub frame is like a strut brace, just fit the solid mounts in the link above and all will be good
    A strut brace is meant to brace the struts at the top, there is now way you can fit one to the rear of the S3
  7. ANDYTQ
    ANDYTQ Well-Known Member
    1,186
    106
    I fitted s3 front upper and lower to my a3 quattro,it did seem a bit tighter and due to being vag parts they were quite cheap too.
  8. superkarl
    superkarl MAN OF STEEL
    9,612
    2,481
    as andrew said, those braces dont brace anything lol.
    i think on a modern car there is V little to be had by strut braces, our cars are well built enough not to have masses of flex
  9. Andrew@A.L.D
    3,879
    617
    Solid subframe bushes for the win
    The standard S3 lower brace can be bent by hand so if i can do that then its not much good under the car
  10. Dani_B19
    9,382
    403
    Oki doki, ive already got the solid frame bushes fitted, love them, fitted them a while ago.
  11. Yohan87
    Yohan87 Guest
    So...
    Solid subframe bushes = Yes
    Strut braces = money that could be spent on solid subframe bushes (although upper front might be worthwhile)
  12. Andrew@A.L.D
    3,879
    617
  13. vfr800
    vfr800 Active Member Team Dolphin Grey Audi S3 quattro Audi A6
    775
    57
    Depends on what plane it's meant to act as a brace: tension or compression? if it's tension you could theoretically use a steel cable which would be very flexible in every way except under tension.
    But is was taken off later models/not put on all models and is extra weight. Who know's whether it's worth it.
  14. Andrew@A.L.D
    3,879
    617
  15. vfr800
    775
    57
    Bottom of the subframe I think.
