Strut Brace
Nitro Sep 29, 2009
  1. Nitro
    Nitro Member
    183
    Is it ever worth fitting a front Strut Brace to an A4 2,8 quattro ? Its a 2000 year model
  2. aragorn
    17,956
    701
    Yer S4's came with them as standard, as did 1.8TQS's
    Not sure if yours will, but if not you can buy some brackets from an A6 and use a redrilled S4 bar for not very much money.
  3. Broken Byzan
    13,237
    465
    It should have one fitted already. look beside the battery
  4. Nitro
    Nitro Member
    183
    Thanks, I can't see one fitted to my 2,8 quattro. Does any one have a photo of a strut brace for this car
  5. Nez
    Nez Member
    598
    I have S4 and I don't see any Strut Brace on my car :( can someone please post a picture of their S4 with Strut Brace :)
  6. aragorn
    17,956
    701
  7. Geeman
    Geeman Low Life
    1,318
    Interesting... there's an A6 in my local breakers yard.
    Might be a winter mod for mine then.
  8. OllyS4
    OllyS4 Member
    143
    Mine is a pre-facelift S4 and i can't see one on my car !
    Thats no to say mine has'ne been taken off in the past
  9. olds_kool
    olds_kool Active Member VCDS Map User
    1,089
    13
    as mark said should already be fitted to a 2.8 facelift and an s4, but you do have to look
    both mine had them from factory
  10. aragorn
    17,956
    701
    Thinking about it, i dont know if craigs S4 has one either.
    I've had the battery out of that to clear the scuttle drains, and dont recall seeing it...
    Olly: if it was there, you'd see the brackets, as they're part of the shell on A4/S4's that had it from the factory...
    I wonder if its a facelift feature? They defo tweaked around with the suspension going to facelift, i wonder if this was one of the additions?
  11. olds_kool
    1,089
    13
    my tdi is pre facelift, should be fitted to all 98ish on v6 and quattro models
  12. aragorn
    17,956
    701
    ye, vagcat says S4 and 6-cyl TDI for 1998 models.
    I'll get craig to have a look, it is tucked out the way so maybe i just havent noticed it!
  13. olds_kool
    1,089
    13
    i didnt know i had it till i went to fit one!
    id bought parts for my old 1.8t but sold car before i got around to fitting, so one day i went to fit them to the tdi only to find one already there
  14. aragorn
    17,956
    701
    i remember you posting about that at the time actually :p
  15. olds_kool
    1,089
    13
    aye its fitted to lee's new car
  16. Dan Gliballs
    Dan Gliballs Active Member
    1,568
    My 99 prefacelift has one.
  17. OllyS4
    OllyS4 Member
    143
    Silly me, i just check and i DO have one (99 S4) but it is very well hiden.
  18. Nez
    Nez Member
    598
    Man I have to look at my S4 too then :) if you guys S4 has it then mine should have it too :)
  19. Broken Byzan
    13,237
    465
    Not the best pic, but it's hiding in there
