Strut brace
ScottD3 Feb 3, 2012
  1. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 saloon Team Akoya TDi
    15,165
    1,124
    Who was it that was asking about front strut braces?
    I think its been talked about before but I'm not sure.
    any where, he is some more information.
    Audi A6 strut-bar: 4B0 805 645
    Bracket:4B0 803 357 A
    Bracket:4B0 803 358 A
    Screw (4x): N 019 700 4
  2. Jason.s
    Jason.s Active Member
    2,879
    348
    Foxy i think
  3. Broken Byzan
    13,237
    466
    I fitted one of these to my last car, perfect fit over those omp things that hold the bonnet up.
    Ideally the TQS's have them as standard, so one less extra to buy,lol
  4. Jason.s
    2,879
    348
    Mines pretty snug against the bonnet but doesnt push it up and hasnt damaged it so its fine. Adds to the bling! :laugh:
  5. Bradderz_1988
    3,988
    261
    I never new my car had one of those as standard I'm going to check to make sure it is there as ive never noticed it when the scuttle has been off lol
    You learn something new everyday !!
  6. Jason.s
    2,879
    348
    It doesnt..Its A6/S6 only as stated on ETKA..
  7. Broken Byzan
    13,237
    466
    the TQS has the plates welded onto the strut tops and then uses that bar.
    To make it fit a normal car you need the A6 strut plates and the bar itself. But because it's from an A6 it needs a few tweaks
  8. ScottD3
    15,165
    1,124
    something mm cut off one end for it to fit.
  9. tonya4
    tonya4 TDi Powerrrr
    408
    afaik S4 and tqs have the brackets welded in place,but use a different bar.I used an A6 brackets and bar,and cut approx 40mm off one end and drilled new holes.
    tony
  10. ScottD3
    15,165
    1,124
    I knew you'd belong with the correct measurements. :D
  11. Foxmeister
    Foxmeister Fired Up!
    1,785
    Yep, was me, i needed the part numbers and ideally will be able to "colour" the application in the end also, dont mind a bit of customising to get it to fit, whole point of the car really! lol.
    Cheers to Scott for the info req! Good man, beer token owed!:arco:
