Struggling with RNS-E retrofit
audicruiser May 4, 2012
  1. audicruiser
    audicruiser Audi Heaven
    1,865
    I am trying to fit a MK1 rnse to my car. My car is a 06 build and had the old style double din symphony stereo. I have bought a cable and connected up. Moved Bose pin from 3 to 7 as this is an early build car.
    Problems I have are
    The unit doesn't switch with ignition
    The unit won't navigate anywhere even though I see 7 sats but the unit knows where I am when stationary
    The radio part of the dis is now missing
    Are all the above due to the coding not being carried out yet? I have Bose and iPod dock and that's it.
  2. Johnny Bravo
    Johnny Bravo 6+1 Gears Audi A3
    898
    69
    You should code it and see if you still have these problems.
    Did you used an adapter, like the ones from kufatec or you already had quadlock?
    Check out THIS thread for coding and other details.
  3. Ash187
    7,489
    742
    sounds like you have the wiring wrong.
    what was the adapter kit you used?
  4. jb0o
    jb0o North East Forum Moderator Regional Rep Site Sponsor VCDS Map User
    2,664
    118
    Sounds to me like its not coded to CAN
  5. audicruiser
    1,865
    Cheers guys, looked a bit deeper and it's wired right but due to it not coded it's not doing what it should. It looks like its coded for an A4....
  6. jb0o
    2,664
    118
    If its coded for an A4 then it's not coded for CAN as A4's are K-Line, which makes sense if the Unit isn't turning on with the ignition.
    What Plug&Play harness did you buy?
    Don't know why it would be coded for an A4 though as they're different fitments... unless someone did the 8L A3 mod, as that is also on a K-Line.
    Ultimately, you need it coded.
  7. audicruiser
    1,865
    Job done, all coded and working a treat. Thanks for the input :beerchug:
