Strong smell (diesel?), what's wrong?
immo Sep 8, 2013
  1. immo
    immo Stop me
    275
    40
    Coming from the exhaust, only notice is when I get out of the car while the engine is still running. Very potent, must be fuel. But there's no smoke. Fairly certain this got worse when the injector recall was done.
    It also misfires a fair bit at low rpm. Some days it's fine though, doesn't seem to be any routine to it.
    Not found any solutions through searching :( Car is in for MOT and service next week so hoping I can pinpoint it by then. What are my options?
    Kimovitzh likes this.
  2. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    Have you had it scanned with vcds? Where in Suffolk are you?
  3. immo
    immo Stop me
    275
    40
    No, I'm Ipswich, work in Diss
    What will a scan tell me then?
  4. AudiMafia
    AudiMafia Member
    403
    13
    it scans for a fault within the engine, injectors, cylinders etc, try to scan it see if anything comes up?
  5. immo
    immo Stop me
    275
    40
    I had it scanned at the weekend and no faults... not what I was expecting. Could do with some more suggestions
  6. pablo
    pablo Active Member
    985
    60
    tandem pump gasket went on my passat (2.0 TDI). cheap and easy fix. its on the side of the head (pass side). look down the side of the head/block and top of gearbox for signs of leaking diesel.
