Strangely long cold start
Acheron Oct 3, 2012
  1. Acheron
    Acheron Active Member
    271
    30
    So I had my remapped by from Revo stage 1 to stage 2 and the very next day I noticed that my cold starts have increased in length by probably around 10x for some strange reason:
    Essentially the car idles @ 1100rpm for over a minute now with the exhaust making a hell of racket until it slowly drops down to the usual 900rpm. Now I'm not sure if it's just coincidental or if the map has resulted in this, but I did query this with Revo who stated that it's due to the decat and the increased time taken for the sensor to warm up without the catalytic converter in place to absorb heat generated by the "SAI" (Secondary Air Injection?).
    The above would make sense, BUT I've had the decat in for quite a while and the issue only started recently (after the new map)
    Any ideas?
  2. mjr901
    mjr901 Guest
    Not gonna lie buddy, that sounds horrific.....
    My S3 does its usual cold start like yours, so that length of time is normal, and all is fine, but yours sounds rough?
    ive got full 100 cell milltek and mines silky smooth...
    If thats the original backbox have a look at the valve that opens and closes with increased throttle as it could be rattling around.
    As after the initial warm up has finished all goes quiet... ie less revs so no need for increased outlets ie, valve shut.
  3. jaydav2306
    jaydav2306 Member
    217
    I had mine failedto start for the first time the other day, the revs dipped and it felt like it wanted to not start then comes to life, I have had the plugs changed as well, what else can cause dodgy starts??
  4. mjr901
    mjr901 Guest
    Sounds like air mass sensor to me.
  5. RYes3
    RYes3 Active Member Team Nardo Audi RS3
    919
    198
    43
    I'm sure I read somewhere the other day that someone had had an update to their Revo map and this was an issue they had seem too. They didn't like the map and went back to the previous version I believe.
  6. Twizzler
    Twizzler Active Member
    489
    37
    My Countax sounds just like that and I've not had it remapped yet.
  7. Silky-S3
    Silky-S3 Is loving his new 8V S3!
    1,407
    343
    That's well rough, mine S2+ does not do that at all. Something is amiss for sure!
  8. Acheron
    271
    30
    Not sure if it's perhaps related to the fact that it is a non-resonated, complete decat section (no mini/sport cat) which is quite a bit bigger than the stock pipe (76mm) or perhaps even the grade of stainless used that gives it an almost tinny quality at low revs.
    I'm pretty stumped actually. :crying:
  9. S.
    S. Save the manuals Team Ibis TFSI Owners Group Audi S3 quattro Manual
    2,019
    551
    my exhaust snapped 2-3 times, broken mounts and it did make some kind of rattle noise.
    get under the car, and take look at the mounts near the turbo. that might be causing issues. mine did.
  10. Acheron
    271
    30
    So the DP itself doesnt appear to be the culprit after cold starting the car on a lift and listening for any potential knocking from underneath.
    Looking into the issue I've seen everthing from the rear PCV hose, various vaccuum lines or even exhaust lifters as being a possible cause. Anybody that can confirm, deny, shed some light on those?
