strange whistling noise from my s3 engine!!
gaz24s3 Jan 11, 2014
  1. gaz24s3
    gaz24s3 Member
    34
    Hi, ive got a random whistling sound coming from my s3(2008) its currently running a stage 2+ revo map!! the whistling sound occurs when i accelerate hard upto 70ish then will stay on until i slow down to about 25 mph.. to me it sounds like it is coming from somewhere near the engine cover!
    here is a vid to listen to this random whistle..
    audi s3 whistling engine noise?? - YouTube
    cheers for any help
    Gaz
  2. Craig Cull
    Craig Cull Well-Known Member
    2,289
    1,015
    Does it disappear when you brake? Could be a sticky brake caliper? Just a thought?
  3. gaz24s3
    gaz24s3 Member
    34
    no mate!! i drove from conwy(north wales) all the way to stoke - on - trent & the noise stayed on for 80% of the way!! theres no loss of power, just this annoying noise!!
    cheers Gaz
  4. Craig Cull
    2,289
    1,015
    Could be a noisy alternator bearing? Or even a noisy aircon compressor? It's a tricky one really :/
  5. Chillout
    Chillout Active Member
    607
    Don't think it sounds like the pcv but is it evident when stationery and try a/c on and off as above
  6. Boydie
    Boydie Boycie VCDS Map User
    3,207
    314
    Does it whistle when you rev at idle?
    Try a few things:
    Turn ignition on with aircon, check for noise
    Turn engine on with aircon, check for noise
    Turn engine on with aircon, rev the car, check for noise
    Turn engine on without aircon, check for noise
    Turn engine on without aircon, rev the car, check for noise
    Drive car with aircon on
    Drive car with aircon off
    Etc..
  7. gaz24s3
    gaz24s3 Member
    34
    the noise only happens when the car is under load and never happens when it is stationery!! thought it could of been the air-con myself , i drive 90% off the time with it switched off thou.. its still there with air-con off or on and switched system off and still there!!
  8. Boydie
    3,207
    314
    Possibly a small leak?? check all your pipes - do you have an after market intake on the car?
  9. gaz24s3
    gaz24s3 Member
    34
    yeh ive got a twin forge intake on it. i did originally think it was the intake so i put the stock in take and cover back on and noise was still there!! next option i was thinking was the forge dv valve what it could be, so i will trying the stock 1 in next few days!
  10. mjr901
    mjr901 Parts Manager - (Main Dealer) Gold Supporter Audi S3 Audi Main Dealer
    3,585
    1,053
    Sounds as if it's circular motion orientated.
    So what ever it is I think it Spins, Wheel, Turbo, Pulley Bearing, Wheel Bearing, Tensioner, Cam?
    Checked your cam follower?
    Does sound like brakes aswell, like handbrake seized.
  11. gaz24s3
    gaz24s3 Member
    34
    ok thanks for the info, i will 1st change the dv valve back to stock just to eliminate my upgraded parts(piece of mind)! cambelt and pulleys were changed 1 year ago so shouldnt be them.. ill check the brakes as well, hand brake does seem looser than normal but noise only comes on when i accelerate hard to 70 then disappears under 25 mph!!
  12. Craig Cull
    2,289
    1,015
    If it's under load, I'd be checking my boost pipes or even the intercooler. Pressure test could be an idea? I guess it's just a process of illimination...
  13. gaz24s3
    gaz24s3 Member
    34
    hi guys ive been to audi today to try get this problem sorted, but no luck.. they think its something to do with a breather pipe ( air leak sound ) but they are not sure where .. they told me to put everything back to standard and they would work from there!! im running stage 2+ so need to change a few parts then..
    cheers Gaz
  14. Dan-Jnr
    Dan-Jnr Well-Known Member
    1,232
    377
    Take it to a specialist to sort, not Audi.
  15. gaz24s3
    gaz24s3 Member
    34
    I have taken it to PSI tuning in Stoke-on-Trent only a quick visit though and couldn't find anything as it only happens under load. .getting it booked in again for a full day so they can put it on the roll
    ing road and give it a proper going over!! just really annoying as it dosnt stop when cruising at 70..
  16. gaz24s3
    gaz24s3 Member
    34
    Hi guys finally got the noise sorted.. it spent 2 weeks at psi tuning in stoke to find the noise a lot if head scratching too, ended up being the centre propshaft bearing!! expensive job to get fixed but all nice and quiet now..
    cheers Gaz
  17. Forbzeeee
    Forbzeeee Well-Known Member VCDS Map User Team Sepang Audi S3
    863
    357
    Glad it's sorted. How much did it cost?
  18. gaz24s3
    gaz24s3 Member
    34
    not much change out of £1500 because you carnt buy the parts separate, so had to have a new propshaft etc
  19. Forbzeeee
    863
    357
    Ouch!!
