strange whirring noise when shut down
mikeya4 May 13, 2009
  1. mikeya4
    mikeya4 Member
    241
    15
    my 98 2.5 tdi makes a wierd noise when you turn it off, it sound like air pressure but it whirrs down? so difficult to explain but doesn't sound right, any ideas?
    cheers
  2. impster
    impster Member
    92
    my A4 1.9TDi does the same - I'm told it's the Aircon system?
  3. mikeya4
    mikeya4 Member
    241
    15
    yeah probably right, it doesn't sound metallic so im not too worried just doesn't sound right
  4. NHN
    29,353
    1,720
    Has that engine got the secondary air pump fitted as I had that on my S3/4 & made strange noises at times.
  5. impster
    impster Member
    92
    I would guess the aircon system (having thought about it) as it changes low pressure gas into high pressure gas, so at any one time, whilst operating there are 2 diferent 'pressures' in the system maintained by a pump of sorts.
    On shutdown, as the pump is no longer turning, this pressure (i guess) equalises throughout the system, and that may be the noise that's heard?
    Only a guess mind, I could be completelly wrong.
  6. mikeya4
    mikeya4 Member
    241
    15
    thanks for opinions, i've found out it doesn't do it on short trips only after the cars been running for a while, would the aircon thing still do it even though i don't use it?
    cheers
  7. mikeya4
    mikeya4 Member
    241
    15
    also i don't know if it has a secondary pump but its quite a deep sound
  8. Broken Byzan
    13,237
    465
    mine gurgles when i stop, from the bulkhead area drivers side. Aircon is what causes mine. I wouldnt have thought a 98 had a secondary airpump. Maybe its just the viscous fan slowing down?
  9. mikeya4
    mikeya4 Member
    241
    15
    yeah could be it does seem like its coming from the drivers side. i guess i will have to inspect a bit more
  10. alex-qts
    alex-qts Member
    59
    yeh mind does it too, 2000 quattro t sport, the noise seems to be coming from the drivers side, near to the windscreen wiper area, i looked and there seems to be some kind of preassure valves letting of a hissing sound. and the pipes (metal) are really cold, i think it might just be the air-con priming itself for when you use it. (it only hisses on long trips with mine too)
  11. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    air con gas release when compressor shuts down
  12. mikeya4
    mikeya4 Member
    241
    15
    I think i've found mine, as strange as it might seem, it was coming from the air filter housing, i've noticed someone has drilled the filter box, its definitely sounding like its from there, random
