strange whirring noise coming from drivers side front wheel
bigblokey0 Mar 25, 2007
  1. bigblokey0
    bigblokey0 Member
    745
    i got a strange noise coming from the drivers side front wheel as if something is catching at first i thought it might be the mudflap but on closer inspection theres nothing in the way that i can see the noise is intermittent and only does it in a straight line and it also does it with the car in neutral and its gliding
  2. rio678
    rio678 New Member
    Could be a Wheel Bearing?
  3. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    Wheel bearing, CV joint or severely worn brake pads.
  4. bigblokey0
    bigblokey0 Member
    745
    the brake pads are new, i checked the cv joints they look ok could be wheel bearing i spose ill check that
  5. Rev-head
    Rev-head Active Member
    2,987
    Wheel bearing jack up and check for play
  6. fjtwelve
    fjtwelve Moderator Staff Member Moderator
    770
    10
    Failing cv joint tends to make the most noise on full lock, bit like a bolt rolling around in a tupperware box
  7. Sinny71
    Sinny71 S55 LKS
    779
    Not sure about the A6 but some cars have a plastic or thin metal shield round the brakes and I have known these to be damaged and bent slightly in the past. During cornering the movement in the suspension components stopped it catching but in a straight line it was rubbing and causing a noise.
    Like I say I'm not sure if the A6 has something like that but may be worth a look in case it is bent or damaged at all.
  8. bigblokey0
    bigblokey0 Member
    745
    everything looks ok however ive only had the noise since it went thru its mot so maybe the mot guy wiggled something loose i dunno it sailed thru the mot as well
  9. Sinny71
    Sinny71 S55 LKS
    779
    If its something rubbing you should be able to see where as it will be clean I guess. Sounds to me it may just be ever so slightly bent, maybe done when the car was being checked over.
  10. bigblokey0
    bigblokey0 Member
    745
    another reason i said it might be something rubbing is because there looks like there tiny marks on the inner tyre tread
  11. Sinny71
    Sinny71 S55 LKS
    779
    Nothing should be rubbing anywhere near the tyre in a straight line. Its bad enough if something is catching a brake disc or a wheel but I'd be pretty concerned if I suspected something rubbing on the rubber..!!
  12. bigblokey0
    bigblokey0 Member
    745
    i am concerned but its not happening all the time i mean since i started this thread its not happened once (touch wood)
  13. alanadams
    alanadams New Member
    a stone trapped between the brake disk and the backing shield?
    Caliper (are they floating) sticking, so one pad rubs on the disk?
  14. bigblokey0
    bigblokey0 Member
    745
    as i say everything looks ok
