Strange tyre wear - any idea?
actionslax Oct 29, 2013
  1. actionslax
    actionslax Member
    34
    got this strange wear on my OSF tyre. I've had the wheels aligned about 6 months ago but that hasn't really helped. I imagine pot holes or **** roads have maybe knocked the slignment out but wondering if it is someting else.
    I now need to get new fricken tyres as the fronts are badly worn.
      File size:
      104.9 KB
      86
  2. 1802010
    1802010 Member
    103
    9 times out of 10 its due to your tracking or unless the wheel is warped and is that the only side its wearing on like that?
  3. Artimus
    Artimus Shortback
    2,017
    485
    Wear on both outer edges is usually a sign the tyre is under inflated... Put some Air in it. :)
    batch and MartayMcFly like this.
  4. actionslax
    actionslax Member
    34
    The drivers side is worn too - out and in but the OSF is particularly bad on the inside. It's like a flat ridge has appeared that's slowing balding the inner wall.
  5. actionslax
    actionslax Member
    34
    Sure the pressure is good. Will check later.
  6. Artimus
    Artimus Shortback
    2,017
    485
    A3's need high pressures. The amount varies from spec to spec, So check your sticker either inside the filler flap or on the drivers door end
  7. MartayMcFly
    MartayMcFly Booooooost VCDS Map User Gold Supporter
    2,763
    354
    Definitely looks like under-inflation. The tyres also look a bit stretched... might just be the angle?
  8. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,819
    197
    under inflation. If theres a lot more on one side of the tyre than the other could also be a tracking issue.
  9. _JJ_
    _JJ_ Member
    33
    I'm with most of the others on this, normally if the tyre is wearing down on each side its under inflated. Hopefully thats the case as its a nice easy fix
  10. leegsi
    leegsi Active Member
    489
    57
