Strange suspension problem
MikeCrum1996 Jan 28, 2018
  1. Tj 0785
    Tj 0785 Well-Known Member VCDS Map User Bronze Supporter Audi S3
    1,757
    379
    This happened on my mk5 golf did it not squeak for a bit 1st or did it just go
  2. tyr382
    tyr382 New Member
    21
    Just get underneath and check everything for damage and movement. Had the same problem with my Subaru b4, turned out to be a lower control arm bushing
  3. Stuart B
    Stuart B Well-Known Member
    2,268
    419
    its what happened to tuffty's S3 - ref Propshaft mid CV - he only found his running the car on a ramp
  4. MikeCrum1996
    MikeCrum1996 Member
    185
    15
    Update - I just got back from the garage and the guy said it’s 100% my passenger driveshaft.. lots of play.. also the driver side had a bit of play so I’m best of doing both at the same time..
    Quick question though, I’m trying to find one in a breakers yard.. do 1.4 golfs driveshaft fit 1.8t?
  5. Siondc
    Siondc Learner!! Ming Blue S3 AMK
    86
    9
    I’m not 100% but I think it’s only the S3 TT and A3 Quattro that share the same drive shafts.
    Tuffty has done a great guide on removing the driveshaft a replacing the gaiters, here:
    http://www.audi-sport.net/xf/threads/driveshaft-gaiter-replacement-tutorial.104037/
    Don’t forget to replace hub nuts too.
  6. Stuart B
    2,268
    419
    don't buy second hand ones - unless they are mine (8 months old) :) - only joking they are still on my car.
    I bought a pair for under £90 and they were fitted for about 2 or 3 hours labour.
    doesn't look like S3 and A3 are the same to me?
  7. Siondc
    86
    9
    Ah maybe not then, my bad.
  8. Stuart B
    2,268
    419
    I only say that because they are cheaper, isn't it to do with the 6 speed gearbox versus the 5 speed gearbox?
  9. Siondc
    86
    9
    Ah yea of course that would make sense. Probably then. The same would apply with golfs then as their 5 speed.
  10. MikeCrum1996
    MikeCrum1996 Member
    185
    15
    I have bought a pair for £70 I’m replacing both as both need doing apparently
  11. MikeCrum1996
    MikeCrum1996 Member
    185
    15
    Does anyone know a good place to get the hub nuts from? Audi want £27 for 2nuts...
  12. Siondc
    86
    9
    Eurocar parts.
    MikeCrum1996 likes this.
  13. MikeCrum1996
    MikeCrum1996 Member
    185
    15
    I literally just ordered 2 for £8 can’t go wrong
  14. MikeCrum1996
    MikeCrum1996 Member
    185
    15
    I’m attempting to replace both shafts on Thursday.. seems fairly straight forward
    Any tips or advice?
  15. Stuart B
    2,268
    419
    mark anything that might affect the alignment and make sure any cap heads are clean all the way down to make sure they are not rounded or turned out undoing them.
    I paid a man to do mine my concern was trying to knock the lower ball joint out and ensuring the lower wish bone was put back into the same place.
    £70 for two new Drive Shafts is pretty cheap where did you get them from?
  16. MikeCrum1996
    MikeCrum1996 Member
    185
    15
    I’m not too worried about the alignment as I’ll get the tracking done a day or 2 after.. also I didn’t buy new ones as I didn’t see your post until it was to late.. but I think they’re reconditioned.
  17. Siondc
    86
    9
    Follow tufftys how-to I linked earlier. Also make sure you have the correct “spline bit”. It’s like a torx but but has 12 splines instead of 6, a mistake I made when I did mine. I removed the ball joint from the hub instead of the wishbone to minimise changes to wheel alignment. Just need a crow foot spanner and Alan key. Make sure you torque the hub but properly.
    It might be worth replacing wishbone bushes as your there too.
    Cheap polyurethane bushes can be found here:
    http://www.strongflexuk.co.uk/audi/s3/99-03.html
  18. SHUk
    SHUk Once Bitten Forever Smitten =]
    318
    19
    Try tightening the wheel nuts. Is it worse round corners?
  19. MikeCrum1996
    MikeCrum1996 Member
    185
    15
    Update: car is now in a much better state.. no more wobbling.. upon inspection of the passenger driveshaft/CV as I removed it.. it fell to pieces.. but I still have a minor issue of what sounds like a wheel bearing noise only happens at 20-30mph then goes at 40mph
  20. MikeCrum1996
    MikeCrum1996 Member
    185
    15
    I was thinking as I removed ball joint and arb link maybe I’ve messed up the alignment causing tires to rub ??
  21. Siondc
    86
    9
    They would rub not matter what speed your doing though. Does the noise change with steering angle?
  22. MikeCrum1996
    MikeCrum1996 Member
    185
    15
    If I turn left the noise goes but all the shaky ness has gone
  23. MikeCrum1996
    MikeCrum1996 Member
    185
    15
    I’m getting an alignment tomorrow so hopefully cures it
