Strange stuttering while coasting. advice needed please
bertiebasset Dec 19, 2012
  1. bertiebasset
    bertiebasset New Member
    21
    Hi all,
    Fairly new TDI s-line owner here and I'm loving looking through this forum.
    Spotted a potential issue last night and as the title says when coasting in neutral the car runs fine but as soon as I apply a little brake the idle starts jumping around like a miss fire. Anybody had this before or can shed any light on it?
    Cheers all..
  2. Geraldy212
    Geraldy212 Sportback owner
    565
    42
    Never had this Bertie, but here is a suggestion. On the TDI, vacuum for the brakes and other needs is supplied from the tandem pump, driven off the inlet camshaft. It is called a tandem pump, since the unit is combined with a fuel pump. Anyway, as far as I know this pump supplies the brake system, but also provides vacuum for the exhaust gas recirculation (EGR) system as well. It may supply vacuum to other engine management devices too. I am sure other members will be along to comment more on this. Anyway, I suggest you might like to get a mechanic to go over all of the vacuum pipes and connections. That is the only definite link I know between the braking system and the engine management. Good luck.
  3. bertiebasset
    21
    thanks for the info Gerald. can anybody else confirm Gerald's thoughts or point me any other direction?
  4. Geraldy212
    565
    42
    Bertie, I forgot to add, that it would be a good idea to have the car scanned (VCDS) to see if any fault code had been thrown up. If so, that would help to diagnose which area needs looking at.
