Strange rhythmic clunking/vibration
Mollygoogle Sep 16, 2013
  1. Mollygoogle
    Mollygoogle Member
    262
    10
    1.9 130. The car has been running absolutely fine until yesterday morning. When I started it up there was a strange vibration through the car, a rhythmic clunking and a rough idle. I didn't have time to look at it so left it until today.
    I checked the fluid levels which are fine. Fired it up. It now idles fine. I took it for a short drive and it drives fine. The clunking noise seems to match with the item boxed in yellow moving from side to side. Could just be a coincidence as I'm not that knowledgeable on engines and don't know what it is or whether it is supposed to be moving or not. Any ideas
  2. glenandem
    glenandem Active Member
    786
    64
    Do a search for alternator clutch pulley, if your tensioner is bouncing about will probably be that!
  3. Mollygoogle
    Mollygoogle Member
    262
    10
    Thanks for that, I'll have a look about
  4. Mollygoogle
    Mollygoogle Member
    262
    10
    A quick look around on here and watch of vids, etc, shows that this is exactly what it is. Thanks for the heads up
  5. glenandem
    786
    64
    No probs, I did one on a passat a few years ago and the alternator is easy to get out but think you needed a multi splined socket if I remember right on the actual pulley!
  6. Ian2012
    Ian2012 Active Member
    473
    29
    You do and they are usually on f****n tight
