strange revs problem
ex_scoobydoo Sep 25, 2010
  1. ex_scoobydoo
    ex_scoobydoo Member
    179
    hi
    i have noticed a strange problem in low revs, example: when pulling away from junctions slow the car seems to get to around 2-30000 revs then it has symptoms as if its running out of fuel, it sort of hesitates, like a slight judder until i change up a gear then, it will do this through to third, after that its fine, sometimes in 4th 5th if i hold the accelerator in the same position i get a slight flutter. if i power through the gears from a stand still, no problem, its nice and smooth, i notice this is intermittent, it wont happen all the time, and it makes no differance if the car is warm or cold. i have checked all breather pipes and their is no signs of splits, and last week it was on a snap on diagnostic machine and came back with no apparent faults.
    can anyone shed any light or have had the same sort of thing.
    thanks
  2. talentwalsh
    talentwalsh Member
    139
    Coilpacks possibly, pull them out and check for discolouration or corrosion. If they are rusty they could be on the way out.
  3. gavin89
    gavin89 Wana go Low gotta go Slow
    214
    lol You might have ran out of fuel if your engines spinning that fast :p:laugh:
    Sorry back to the point, coilpacks most likely mate, I would also just check your TB. You can rule out the MAF as it should chuck out a code on VAGCOM.
  4. talentwalsh
    talentwalsh Member
    139
    :lmfao:
  5. ex_scoobydoo
    ex_scoobydoo Member
    179
    haha, but yer its not the maf, i only changed that about 7 month ago for a new Bosch. not ruled out, but like you say it wasn't picked up on a scan
    i will check coil packs, and report back :) bty what is short for TB im a bit rusty myself and forgot the slang :p
  6. gavin89
    214
    Haha no worries its throttle body.
  7. mo_s3
    mo_s3 New Member
    27
    hi mate, my mate had a similar problem but his use to switch off when changing gear. all it took was some throttle body cleaner and cleaning out his intake pipe which had alot off oil inside for some reason.
  8. ex_scoobydoo
    ex_scoobydoo Member
    179
    thanks for the reply's
    im going to check the coil packs today, and clean the throttle body, my intake also seems to collect oil to, any reason for this?
  9. mo_s3
    mo_s3 New Member
    27
    dont know why it collects oil mate, im sure its not suppose to. a sensor in the intake pipe gets covered in oil near the breather section, so you need to take it apart and really clean it out.
