Strange problem
daz2347 Aug 30, 2007
  1. daz2347
    daz2347 Member
    82
    Now its getting darker! I have started using my lights only to find when turning them on to either side or main the front fog lights come on?
    Any idea's?
  2. jcs356
    jcs356 Brum brum
    2,734
    70
    I had this with mine - and the cause was slightly strange so not sure if it will be the same for you!
    When I'd previously removed the switch to try to fix the switch illumination. Anyway, when I put the switch back in, I managed to break a small piece of plastic on the switch mounting, which wedged itself into the switch mechanism. So when I turned the switch to turn the lights on, it also popped out a bit, caused by the small bit of plastic, to turn the fogs on.
    I only found out this was the cause when I took the switch out again to have another go at fixing the illumination and this small bit of plastic fell out and the problem with the fogs stopped.
