strange problem with hit n miss power on my a4
jamesey Nov 9, 2013
  1. jamesey
    jamesey Member
    98
    hi ive got a 1.8T a4 and when i drive it hard like in 2nd and accelerate it put you back in your seat but then dies off and then power comes on again , its very hit n miss what can cause this sort of power loss ive not got any faults on vagcom.
  2. jamesey
    jamesey Member
    98
    maybe a coil pack? how do i know if its had the recall? ive got push in ones not bolt down? bosch
  3. hades-
    9,481
    646
    a failed coil pack will make the car misfire
    and make the em light flash
    GET IT SCANNED FOR CODES
  4. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    Log some values in VCDS, I had a similar issue when my MAF was problematic and not metering air correctly.
  5. Avnt
    Avnt Active Member
    240
    25
    Ive had it on a turbo car before where it was bad fuel. Made it feel like it was misfiring all the time. Put some fresh v power in and was perfect again.
