Strange problem, revs going up and down and engine cutting out while driving!!
silverswish Apr 25, 2012
  1. silverswish
    silverswish Black 1997 Audi A3 1.6
    For the past two weeks my car has developed a major problem. While driving, the engine will rev to 4k from 2k, back down to 1k and sometimes it stalls. It's not a small drop in revs but a major drop that causes the car to jerk. The car will even stall and randomly start a split second after!
    Any ideas guys?
  2. camscockle20vT
    camscockle20vT The stigs ugly brother
    1,740
    77
    Get it checked on vag com for fault codes. Id suggest checking the pipes under the inlet manifold and give your throttle body a clean and reset it. Hope this helps.
  3. Lemon S3
    Lemon S3 Alex
    1,390
    41
    Could be a split vacuum pipe, like said above, check under inlet.
  4. Nilz
    11,356
    894
    Defo sounds like a piping issue in the engine bay.
  5. camscockle20vT
    1,740
    77
    This thread has jinxed me :( my car has just cut out at low revs. First thing im going to do is clean my throttle body.
  6. camscockle20vT
    1,740
    77
    This thread has jinxed me :( my car has just cut out at low revs. First thing im going to do is clean my throttle body since i know my pipes are all fine.
  7. Nilz
    11,356
    894
    Let us know how you get on dude!!
  8. IrishDave
    IrishDave Active Member
    682
    45
    Faulty MAF
  9. silverswish
    Could engine sludge cause this problem?
  10. silverswish
    Ok the car has now started backfiring, like a huge pop/bang when driving, what is going on??
  11. L33h
    L33h Member
    215
    Sounds alot like your MAF to me. Try disconnecting it and if if there's any difference. If theres not then it deffinatly if the MAF.
    The backfiring may be caused by a faulty MAF sending too much fuel through the system.
  12. silverswish
    Definitely not the MAF, I disconnected it and the engine struggles to stay running.
    Any more ideas? I haven't had the car serviced in ages which doesn't help. Spark plugs haven't been changed for at least 17,000 miles??
  13. IrishDave
    682
    45
    The car will not run with the maf disconnected. Sounds like a similar problem I had on another car which turned out to be faulty maf's.
  14. silverswish
    But surely me disconnecting the maf and the engine struggling more so than when it's connected means that it is not the maf?
  15. AndyMac
    9,832
    46
    Yes if its worse or the same with the MAF disconnected then its NOT the MAF. The car should run fine with it disconnected
  16. silverswish
    Maybe it's the head gasket? Started to lose some coolant too and slight mayonnaise on the oil cap.
