Strange Power Problem
cybrey Apr 25, 2005
  1. evotista
    evotista Member
    118
    Drill, Al,
    Hesitation can be caused by any of the following
    dodgy DV (N710)
    Pipe leak
    Throttle body
    Lambda Sensors
    MAF (AMM)
    Coolant Sensor
    N75
    N249
    This is an intial list as i understand it...there obviously could be more (ECU, injectors?) If throttle body is now eliminated, at least with yours Al you've tried most other things then you need a VAG-COM session and get logging the 2 lambda probes to check their values. HTC has the info needed to do this...send him a pm. At least this way you can check if values are as they should be.
  2. AL_B
    AL_B Well-Known Member Team Daytona Audi S3 DSG
    1,772
    212
    RE: VAG-COM session, well volunteered Evotista!!! I notice you are in the North West! hahahahaha /ubbthreads/images/graemlins/smile.gif
    AL
  3. AL_B
    1,772
    212
    Cheers mate.
