Strange noises behind dash
bonerp Oct 3, 2007
  1. bonerp
    bonerp Member
    180
    Hey,
    On my 02 1.9TDI A4, strange noises occur! Sounds like vents opening and closing. Seems to happen pretty much all the time, even when I turn the car off for a short while after.
    Is this normal???
    Paul
  2. jase0851
    jase0851 Member
    789
    the noise is the flaps adjusting to divert air where you want it to go this should only happen when you change the air direction on the aircon unit
  3. bonerp
    bonerp Member
    180
    thats what it sounds like, but its doing it all the time.
  4. Nelson15
    Nelson15 Member
    71
    Mine does it as well, we'll see what other folks say....
  5. jase0851
    jase0851 Member
    789
    you could try disconnecting the battery for a while ? see if it resets someting or if you know anyone with a vagcom
  6. TINTMASTER
    TINTMASTER TORQUETRONIX-DONEGAL
    61
    Might be your heater controller! the m8s started palying up and when he replaced the dash control unit it sorted itself out!
  7. bonerp
    bonerp Member
    180
    Everything seems to work fine tho!!!
    Except my heated mirrors dont seem to be demisting.
  8. JGrant1285
    JGrant1285 Sir Scouser Benitez
    225
    mine does it too!!!
    Its like a short creaking noise???
    its done it for a while too, everything works fine tho, so not to worry!!!
  9. m40rcd
    m40rcd Sunny Delight
    104
    Mine does it too, like you say, even when the key is out, but it all works fine. I was curious about it too
  10. Silver Quattro
    Silver Quattro 1st Quattro Deffo not my last...
    100
    tis ta same here get the noises but just decided to put up with them as nothing really happens to indicate anything is faulty etc,il be getting worried if the noises stop now lol
  11. samuelt
    samuelt Member
    383
    min does it to 02 130 tdi. Did your heated mirrors ever work?? min does not have them (sport model) ! I have wiring and i belive that they turn on when you turn on the rear glass heating. £50 for the Glass!
  12. duane
    duane Member
    142
    My wifes B6 TDi does the same thing, my B5 S4 does it aswell.... As other's have said, if everything works as it should i wouldn't worry......
  13. bonerp
    bonerp Member
    180
    I'm sure my book says mirrors only warm up at a certain temp! I'll check - and i'll put up with weird noises!!!
    Went to Weymouth and back this weekend. This car is awesome!!! 500 miles at least to tank of the black stuff woohoo!
  14. bonerp
    bonerp Member
    180
    just checked - think I'm going nuts!:tocktock:
