Strange Mis-fire - AUQ Engine
petle91 Nov 25, 2009
  1. petle91
    petle91 New Member
    Hi All,
    The problem is that when driving normally everything seems fine but if I use between 90-100% throttle, when I get to full load (starting at 2500rpm) I start to get a misfire. I have plugged in VAGCOM and it shows an intermittent misfire on cylinder 3. I have changed the spark-plugs and all the coil packs which didn't resolve the problem. I even swapped the coil packs around in case one was faulty, but still the cylinder 3 issue.
    It's booked in a Midland VW this weekend, but just wondered if anyone had ever had a similar issue or any ideas?
    Car: 2004 Seat Leon Cupra 20VT
    Engine model: AUQ
    Thanks,
    Peter.
  2. dc240969
    dc240969 Member VCDS Map User
    925
    l have cylinder 3 run hottest, so l was told. Changing the downpipe sortted me out.
