Strange idle video evidence normal sound?
basscrazy Apr 10, 2009
  1. basscrazy
    basscrazy Member
    60
    As u may have caught on the odd post i have a dodgy idle when it coughs like it tries to misfire but then goes back to normal when it does this there is a clunk as obviously its kicking back to normal i tried to explain but was hard to so popped the phone under the car and let it idle for a while did a 15 min vid and selected a min where it was doing it (sometimes does it more often then others)
    The two little clunks you hear is when it coughs and tries to misfire...Is this my bottom end going etc or is this literally the misfire sound from underneath
    If i put small amount of revs ie 1.5k instead of 1 it wont do it at all
    http://s289.photobucket.com/albums/ll238/Basscrazy_/?action=view&current=Movie-1.flv
  2. basscrazy
    basscrazy Member
    60
    to be fair even if its incredibly small revs so the idle is constant it doesnt make this sound
  3. basscrazy
    basscrazy Member
    60
    no one even with the vid...
  4. MikeA3
    MikeA3 Active Member VCDS Map User
    1,178
    Have you scanned the car with vagcom to see if it's logging any error codes?
  5. s3ollie
    s3ollie Member
    762
    just a guess but could it be something to do with your flywheel?
  6. basscrazy
    basscrazy Member
    60
    yea got some vagcom errors getting sorted on friday
    im worried about that click sound
  7. dstructiv
    dstructiv Member
    34
    sounds like a tdi, but im guessing its not? if not bit of noisy tappets and a slight misfire by the sounds of it
  8. basscrazy
    basscrazy Member
    60
    its a 1.8 amk not diesel i put phone under the sump to take that
