Strange Idle/Rough - Intermittent
3.2Sline Apr 23, 2013
  1. 3.2Sline
    3.2Sline New Member
    13
    Hi,
    help and advice please folks??
    I have an Audi a3 3.2 v6.
    Following various vagcom scans, I replaced the MAF for a genuine Bosch air flow meter after some intermittent running problems.
    Now, when I'm driving it usually only when it's warm, I come to a stop and the revs take a couple of seconds to drop down to its idle point, making pulling away uncomfortable/difficult.
    I had an episode last week where I would start it up and it would die immediately unless it had revs!!
    This problem stopped, I am sure it is related.
    Car is still drive able, but not enjoyable.
    What does this sound like???
    Ta
  2. 3.2Sline
    3.2Sline New Member
    13
    Anyone?????
  3. 3265colin
    3265colin Member
    30
    Try a throttle body reset with vagcom
  4. chris.vincent3
    chris.vincent3 Own a BMW now, HOWEVER I still own VCDS! VCDS Map User
    604
    34
    is it possible to adjust idle on these engines?
  5. Chillout
    Chillout Active Member
    610
    50
    Think you can adjust the idle don't know how mine idles at around 640rpm I had a rough idle before I had the audi software update however I still don't think my car idles perfect I take it no codes were logged and the basics are ok like fuel and air filters throttle body alignment is probably not a bad first point of action though along with a clean in case it's sticky
  6. 3.2Sline
    3.2Sline New Member
    13
    Throttle body being cleaned out tomorrow morning.
    Presumably the garage will reset the TB using vagcom after??
  7. Chillout
    610
    50
  8. chris.vincent3
    604
    34
    Don't always presume the garage will do that.
    And to adjust idle on my TDI is as follows..
    Ignition on - engine off
    Select Engine controller 01
    Select Measuring blocks 08
    Select 'Go' in Group 1
    Start Engine ( you may be able to start engine earlier but I don't )
    Hit 'Turbo' button at top of page
    Select 'Done'
    Select Adaptation - 10
    Change channel to 06 and hit 'Read'
    However maybe slightly different for you.
    Also, what fuel are you using? This has been a known problem for cheap fuel.
