Strange handling issue/rear end knock
Chriscooke Mar 4, 2013
  1. Chriscooke
    Chriscooke Clueless!
    512
    25
    Over the past couple of weeks my QTS has developed a slight handling issue. When I go around a roundabout or a hardish right hand turn the rear of the car feels vague and a little unsteady. The rear has also developed a knock which sounds similar to the exhaust hitting the chassis although on closer inspection this doesn't seem to be the case.
    I got the car up on ramps yesterday and can't see anything obvious other than a slight exhaust blow and the rear diff which seems to of sprayed a little oil (will post pics in a bit). I checked the springs which seemed fine as I feared one had snapped.
    I know bushes can be an issue but this seems to of happened pretty suddenly which I wouldn't expect from worn bushes??
    Anything I should check?
  2. Chriscooke
    512
    25
    Pics of rear diff. Could this be my issue or another thing to woory about?
  3. dubster67
    dubster67 Member
    152
    9
    Looks like a "normal" leaky rear diff to me. Probably taken quite sometime for that oil to leak out, plus I'd think if your diff was at fault you'd hear a noise all of the time rather than just a knock going round a corner.
    Can only state the obvious and start with checking all bolts to see if they are tightened properly. Then check everything over including wishbone bushes, track rods, arb, wheel bearings, etc etc.
  4. Broken Byzan
    13,237
    465
    The bushes do tend to wear progressively, but when they go the **** end is quite bad at following the front. I ended up replacing the lot to cure mine. I believe that Allermange (sp) do a rear bush repair kit, and it's a night and day difference assuming the tie rods and ARB are OK
  5. Chriscooke
    512
    25
    Cheers for the tips guys. will see if I can get the car on the ramps at my mates work and have a decent check.
