Strange fault
Matt Sep 25, 2008
  1. Matt
    Matt Active Member
    1,404
    A good few months ago now the speedo needle bulb died. So with it not even being a year old I got it into Audi and they had to change the whole dash pod which I dont mind as Im not paying.
    So that solved the bulb problem but since then when going to start the car the message "PRESS CLUTCH PEDAL TO START ENGINE" doesn't appear. I mentioned this to the garage so they had a look and thought it was a fault with the dash pod and ordered another one.
    It went in today to get the new pod fitted and its still not sorted it so they are keeping the car overnight and have sent off a report to Audi to see if they know what to do. Dont get how it worked fine before but not now! Strange!
    At least its a stupid little fault I guess compared to what some people have! Got an A4 Avant S-line as courtesy car. Only a TDI 140 though.
  2. samuelt
    samuelt Member
    383
    hi Matt
    I have had my 2006/56 A3 2.0TDI 170 for only a few weeks but i have never ahd the message "PRESS CLUTCH PEDAL TO START ENGINE" or had to press the clutch while starting.
    Toby
  3. jamiekip
    jamiekip Guest
    Is this something activated in Vag-Com???
    Mine does it, thought all of them did, nanny state protecting us from starting the car!!!
  4. Matt
    Matt Active Member
    1,404
    It was introduced later on than 56 plate. Mine is a 57 plate. Thanks anyway.
    Jamie - they all have this feature after a certain production date. Mine has just stopped saying it since the new dash pod was fitted.
  5. JamS3
    JamS3 Active Member
    2,258
    20
    Try starting the car without the clutch pressed and it will appear then!!
    My 07 S3 which I dont have now displayed it when the ignition was turned on but my new facelift S3 does not show it but does when you try to start the engine without the clutch pressed.
  6. Fast,not furious
    Fast,not furious Dealing with an OCD
    416
    ....ermm - mine's a Dec 06 build,they don't come much earlier than that,and mine's got it.
  7. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    thought it only came on S3 models - not the "standard" A3s. The earliest S3 build would be around aug\sept 06 from what I understand.
  8. Matt
    Matt Active Member
    1,404
    All I know is that it used to do it and it doesn't anymore lol. Audi garage says it should do it aswell which is why they are investigating it.
    S3s maybe had it from the start but it was introduced later on with the normal A3s.
    I'm missing the extra oomph from my 170 engine so hope I get it back today
  9. Matt
    Matt Active Member
    1,404
    I've got the A4 for the weekend. They are in contact with Audi Germany about it trying to sort it out so want to keep the car.
  10. JamS3
    JamS3 Active Member
    2,258
    20
    Have you tried the above I said?
    Seems you have a updated cluster compared to the "old" on so the new one is not meant to do it!
  11. Matt
    Matt Active Member
    1,404
    Yeah I've done that before and it wouldn't start but still didn't bring the message up.
    Like you say its got to be something to do with the new cluster/pod/whatever you want to call it being a newer version than the original one. If the new one is meant to do as you say above then I would happy with that but at the moment it displays no message at all no matter what I/they do!
