Strange cnok from front right side..
kninio Dec 26, 2007
  1. kninio
    kninio Member
    96
    I have a strange cnoking from the right side front even i have all control arms replace by brand new kit 2 months a go , and the sound come when i accelarete and some times when i slow down , its like something banging.. , could be the strut mount ? or what else can make those noises?
    any help will be appreciated!
  2. Siena
    Siena Active Member
    2,626
    Gearbox or engine mounts?
  3. kninio
    kninio Member
    96
    gearbox mounts changed too , 3 months ago , same with engine one... , could be the strut mounts?
  4. Siena
    Siena Active Member
    2,626
    Yes, very possible top mounts are worn.
    Worn ARB link bars can also cause knocking!
  5. kninio
    kninio Member
    96
    arb link bars changed with the control arms :) i changed all at once , what is still worn the front engine stop mount , but i already bought it and i will change , but the sound is not coming from it i think cos i hear it from the right side.
    about the strut mount is they comon to wear? what wear on them? maybe they were tired since long and i didnt know that? , how can i inspect it?
  6. andybnwc
    andybnwc Member
    752
    ive got a similar knock when on of gas in a right hand bend but got more important things to fix first lol
  7. kninio
    kninio Member
    96
    aha, but you didnt figure it out yet?, does the strut mount comon to fail and make such a noise?
  8. OnTheJazz
    OnTheJazz Member
    37
    Hi kninio, where did you get your kit from?
    I puchaced a kit from ebay about 6months ago, fitted it up then about 2months after fittinf a knock could be heard from the front driverside.
    it turned out that the washer had boken and fallen out, this was the new bolt and washer i got with the kit! i torqued all bolts to specified torque settings, must just have been a **** washer.
    i put the original bolt back in and its been fine since, have a look, could be the same thing
  9. kninio
    kninio Member
    96
    i bought them from lemforder dealer in lebanon , no i figure it out its really the strunt mount cos when i am turning the sound come on , otherwise everything is fine :) , i will buy pair of strut mount and change them! , i had a rear end unstable in my car and today i changed the rear shock mounts and u cant believe what difference it made! so propably the fronts is also wear so i will change and inform you!
    cheers all!
