Stiring soup!!!
S3BN_H May 9, 2011
  1. S3BN_H
    S3BN_H Member
    45
    hiya folks, got my plate fitted today and went out for a blast in the car, not used it in a month or so, and ive forgot how bad the gear selectors are, its done 100k so im guessing new rods will be a great help, ive also seen the mount adaptor thingy above the gear box, short shift kit or whatever it is? lol, anyway that any good ?
    cheers for any help, sean
  2. Westy
    Westy Well-Known Member
    17,443
    1,103
    I've got a short shifter, the red dog bone mount and had my gearbox oil changed and it's fine now.
  3. Syvo
    Syvo IF IN DOUBT GO FLAT OUT
    1,338
    22
    how hard is it to change the gear shifter above the gearbox to a short shift
  4. Westy
    17,443
    1,103
    20 minute job mate. You lock the box in neutral position with a little button on the side of the box (bet you never knew it was there ;) ) then you remove the bracket for the throw movement. Put the new one on and tighten up. release gearbox lock.
    There are 2 shortshift brackets though. 1 for throw/front to back movement, and 1 for side to side movement. I got the throw bracket. Both are around £40
  5. S3BN_H
    S3BN_H Member
    45
  6. Westy
    17,443
    1,103
    That's the one.
  7. S3BN_H
    S3BN_H Member
    45
    cheers mate ill get one of these and get it on, cheers again
  8. Westy
    17,443
    1,103
    It might take a little adjustment of the linkage cable to get it as smooth as possible. It's fairly straight forward as there is a little screw thing by the bracket that lets you adjust it.
    I'd also recommend getting your gearbox oil changed. It made quite a big difference to mine.
  9. steve bain
    steve bain Member
    642
    can the existing one not be modified?
  10. Westy
    17,443
    1,103
    I'm pretty sure you could. I've got my old bracket at home if you wanted to try and mod it.
  11. steve bain
    steve bain Member
    642
    oh. yes please. can pay the postage and if succesful could make a how to...
    Steve
  12. Westy
    17,443
    1,103
    I'll dig it out later.
  13. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Ive got both on and its very close, about 2" of movement either way
  14. Westy
    17,443
    1,103
    Would you say it's worth doing the side to side movement too Dave?
  15. s3dave
    10,110
    736
    Yes but it takes some getting used to, makes the driving exp a lot better
  16. takworldwide
    takworldwide Member
    158
    Just wondering if these would fit an AGU engine/gearbox?
  17. S3 TAM
    S3 TAM Pocket now empty
    624
    10
    any vag 6 speed
    you can get 5 speed ones as well
  18. steve bain
    steve bain Member
    642
    ah, thats a thought. mines and agu a3, so maybe your link wouldn't work on my gearbox....
  19. Westy
    17,443
    1,103
    How many gears you got?
  20. steve bain
    steve bain Member
    642
  21. Westy
    17,443
    1,103
    No good then.
  22. Sam_
    Sam_ Down under
    3,037
    480
    The dieselgeek made a decent difference on mine...
