Still struggeling
jimmer 22 Sep 1, 2013
  1. jimmer 22
    jimmer 22 Member
    66
    Right then, im still having what i thought was a leak problem, basically i get a whisteling noise when i hit boost, and a loss of power, sometimes bad enough that it feels like clutch slip, its not all the time but most. The noise really sounds like a boost leak. Iv also got a bit of a flat spot around 2500-3000 rpm when on part throttle, the car generally pulls very well most of the time, there is also turbo lag after gear changes even if giving it a fair boot full.
    So far i have replaced
    Maf (genuine new bosch)
    Recirc valve (new 007p)
    Puc valve (new)
    N249 bypass
    Pcv delete
    Tryed another n75
    Done a smoke test (no leaks atall apart from the puc valve hense replacement)
    Scanned for codes (no codes)
    Tested actuator (holding pressure and snapping shut nicely)
    Im running out of options, lol.
    I done a 3rd gear wot with my vcds light and got 186 g/s (232.5 bhp) so i am achieving good boost.
    After changing the n75 the syptoms did change slightly but generally the same, (less lag after gear change, louder whisteling, flat spot reduced)
    The car is a 2002 bam s3 with 100,000 on the clock ( completely standard apart from the couple of minor mods above)
    One evening this week i will be fitting a boost gauge and doing some logging with full vcds and hopfully this will shed some light on the situation
    Pls pls can someone offer any other advice, this is starting to get expensive and extremely annoying,
    All help appreciated,
    Cheers people
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    I would throw some new plugs in...
  3. JUS3IN
    JUS3IN 14.0 @ 98mph 2s 60ft
    1,159
    102
    when my relentless manifold came undone there was a loud whistling, maybe one of the manifold gaskets has blown?
  4. jojo
    28,831
    3,485
    Don't know about the whistling, but I'm going deaf from the shouting! :blink:
    <tuffty/> likes this.
  5. jimmer 22
    jimmer 22 Member
    66
    cheers guys will check both of these,
  6. jimmer 22
    jimmer 22 Member
    66
    this made me laugh...
    JUS3IN likes this.
  7. Lavis89
    Lavis89 Well-Known Member Regional Rep Team Sprint Audi S4 Audi A3
    1,757
    598
    Been trying to find a really loud whistle (on idle) coming from my car for the past couple of weeks. Gasket didn't even come across my mind Even though it is painfully obvious now :mad:
