Still some problems
smudge_don Mar 19, 2010
  1. smudge_don
    smudge_don Active Member
    2,944
    Right, the driveshaft issue after the massacre of my old one by some idiots has been sorted
    But now i have a different problem
    Whenever i am travelling slowly, like in traffic, i get a sort of clunking noise that you can feel through the car
    It seems to be rotational, and on the driver side again, where i had the problems with the driveshaft
    Garage that fixed it all for me can't find anything, anyone got any ideas?
    Could it be the wheel/hub/brake disc/heat guard rubbing/knocking against something else as the wheel turns, due to the negative camber i've now got?
  2. Dan!
    Dan! Quattro Drive
    278
    I think that you would have to be running some pretty serious camber before you have any problems like that.
    I don't have my car yet to look at, but the brake/hub/disc/wheel and guard are all going to move to the same camber angle. Only thing that I can think of is the CV joint?
    What was it that was done to the previous driveshaft that massacred it?
  3. smudge_don
    2,944
    Coilovers were fitted, and the driveshaft popped out and wasn't put back into place properly, so as soon as i went to drive away it caused damage which im claiming from the 1st garage
    2nd garage put on a new driveshaft for me, and had them check the noise out over the last couple of days, but they couldn't come up with a solution :think:
  4. Dan!
    Dan! Quattro Drive
    278
    That's really interesting. Does it only do it at low speed and increase frequency as you accelerate?
    CV is the only thing I can think of that would cause this kind of noise if it's rotational. What damage was origianlly caused cuz I'm wondering if it could have over extended the maximum angle of the CV and bent something that is now out of alignment?
  5. smudge_don
    2,944
    Ye that's the weird thing, only very slow speeds
    Seems to be fine when about 15mph, and on motorways it's smooth as anything
    Original damage was to the bearings and the tripodic end of the driveshaft
  6. Dan!
    Dan! Quattro Drive
    278
    I'm at a loss if those bits were fully replaced...
    Sometimes I wish you could just ask them to try a new CV or something to see if that fixes the problem and not have to pay for it. In a perfect world maybe!
    I suppose that slightly damaged bearings would do something similar, but would probably be more of a random clunk than one that inceases and decreases speed noticably.
  7. smudge_don
    2,944
    I don't get why it only happens at slow speeds.....
    It's definately rotational, think i'll jack her up tonight to see if anything is rubbing/knocking, if i can't see anything, take it back again
  8. Dan!
    Dan! Quattro Drive
    278
    Sound like a plan.
    Like I say, if it's something that vaguely speeds up with the wheels but you can't just time them with a watch then there is a phenomena where worn bearings and things will run super smooth at higher speeds even with the wear. Maybe they didn't replace all the damaged bearings or something.
    Let us know how you get on!
  9. smudge_don
    2,944
    Will do, cheers Dan
  10. smudge_don
    2,944
    2 garages have now looked at this new problem and can't figure out what it is :(
    Giving it one last shot before i take it to Audi to have them take a looksie
  11. Dan!
    Dan! Quattro Drive
    278
    Good luck, I hope they find it! Third time lucky and all that! :)
