still not 100% logs inside
karl210 Sep 21, 2012
  1. karl210
    karl210 Member
    324
    Changed maf and plugs today and car is pulling much better low down and off boost so win there
    I can tell there is a boost leak somewhere but it seems like at high rpm its hitting some sort of protection, then after about a second or 2 of then it goes fine again then does it again just before hitting redline. Here is a couple of logs anyway, cant do any better ones as ive only got vcds lite.
  2. karl210
    karl210 Member
    324
    on the second log there was traffic so it was tough to get a good run, i did 3rd and 4th my bad
  3. karl210
    karl210 Member
    324
    and what i think is the n75 duty cycle is 100 all the way through the revs, accidently cut it out of the log
  4. karl210
    karl210 Member
    324
    no-one? :ninja: think i might just bite the bullet and take it to a specialist
  5. Broken Byzan
    13,237
    466
    have you done a log to include block 115?
  6. karl210
    karl210 Member
    324
    only got vcds lite im afraid and will only let me log blocks upto 025
  7. Rosso TT
    Rosso TT Member
    146
    You're pretty much maxing out your injectors.
    20ms at 6000 rpm is 100% duty cycle.
    Specs of the car?
  8. karl210
    karl210 Member
    324
    175k amk engine
    oettinger remap
    n249 delete
    full pcv delete with catch can
    b5 tip with cone filter
    seems to be averaging around 27mpg which seems worse than a month ago
  9. Broken Byzan
    13,237
    466
    you need more logs tbh, im thinking boost leak
  10. karl210
    karl210 Member
    324
    yeah more logs would be ideal, i might go on a hunt for a garage with a smoke machine tomorrow and see what that finds, someone on vwvortex has suggested changing the fuel filter so i will do that tomorrow aswell.
