Still loose steering.... (groan)
QuottroA4 Jan 23, 2011
  1. QuottroA4
    QuottroA4 Member
    179
    If anyone could point me in the right direction there would definately be a drink in it for them!! [​IMG]
    I have still got a problem with my steering being loose as when I am stationary you can move the wheel quite a bit before the wheels move. Its worth mentioning that I have to turn the wheel more that you should need to when cornering and that I have to consently make minor adjustments when driving.
    The problem used to be worse as it used to 'track off' down any groves in the road and or potholes etc. Since then I have replaced the steering rack, track road ends, shocks and all the suspension arms!! oh and 4 wheel alignment...
    So, question is, what else could it be?? Somebody suggested that it could be the subframe that is loose? Any ideas peeps? [​IMG]
    __________________
  2. trev m
    trev m Member
    35
    Is the subframe tight as you mention
    wheel bearings
    steering wheel on shaft tight
    power steering =pump not working all the time /low on fluid /belt loose
  3. QuottroA4
    QuottroA4 Member
    179
    Can the subframe cause this then? Come to think of it do you need to remove the subframe when fitting a clutch on a Quattro as I had mine done late last year along with a new DMF..
    Dont think the wheel is loose on the shaft, if it was the bearing wouldn't it make a right din when driving?
    Re the PSP, I hope its not that as there ££££££!
  4. trev m
    trev m Member
    35
    its just a thought
    wheel bearings yes hum of some sort
    have you jacked the car up and checked for play .grab the wheel at 3 o'clock and 9 o'clock and move in and out also at 12 o'clock and 6 o'clock
    also you can try rocking the steering from left to right and some one look under the car to see what is moving too much do this with the engine off
  5. quattro tony
    quattro tony Member
    167
    The subframe doesn't need to be removed to do a clutch on a quattro. I know i did not have to take it off to do mine. You have prob replaced most things that would cause a steering/ handling prob but have you checked the steering wheel center nut is fully tight ? Is there any wear on the splines between the wheel and the shaft? I would be looking closely at the steering column to see if there are any problems there to check when you move the wheel is the shaft moving in time without delay.
  6. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,811
    54
    iv got the top part of a steering column if that's any helps you mate?
  7. Yappy
    Yappy A4 b6 TDI V6 Quattro Sport
    150
    Maybe a long shot how about the suspension top mount worn that may be the pulling when in ruts because it will change the geometry of the car if not it's going to be a long process this trying to pick this problem hope you get it soon mate
