Stiffening suspension (A3 SE Sportback 2.0 tdi)
Rosario7 Dec 8, 2009
  1. Rosario7
    Rosario7 A3 2.0 Tdi Sportback
    20
    Stiffening suspension (A3 SE SPORT BACK)
    Hi all,
    i have an A3 Sportback SE and am considering lowering and stiffening the suspension as its a bit loose at the moment. I have asked for advice at the local main dealer but they where not very helpful. The question i asked them was if i purchased the Sport springs and shockers would they fit on mine?
    They dint give me much of answer apart from "get some aftermarket one" but i rather keep it all genuine.
    Can anybody help me please??
  2. V6Pete
    V6Pete Now running on Bentley's y'all
    1,491
    Your best bet if you're keeping it OE would be S-Line springs which will drop 20mm or so. These often turn up second hand due to people upgrading.
    But even better would be Eibach springs that are OE quality, will lower a bit more, and ride better than the S-Line.
  3. DPM
    DPM Site Sponsor Site Sponsor
    5,008
    204
    Yeah personally I'd also say go with a set of Eibach Pro springs which will not only be better but also be cheaper.
    Damian @ DPM Performance
  4. Rosario7
    20
    Thanks very much for the info guys. Now what i also would like to know is if it would just be a direct swap between the springs (from SE to S-line/eEibach) or does anything else need changing like the shockers ect.??
  5. V6Pete
    1,491
    Nothing else will need changing.
    If you do fancy changing the shocks later, there's nothing to stop you doing this. But if you're going to be spending some more cash, you might be better off with some coilovers, so you can get the height and ride adjusted to just what you want.
  6. N8
    17,163
    718
    As Pete said adjustable coilovers are the best way to stiffen things up properly...
  7. Khufu
    Khufu Well-Known Member
    5,704
    31
    :scared2:
    well, somebody had to bite :whistle2:
  8. N8
    17,163
    718
    Didn't bite Khufu, I've had experience in A3s of springs/springs and shocks, and coilovers...
  9. devonmikeyboy
    devonmikeyboy As far from JBS as possible !
    1,245
    I bet you have N8 :sex: but i don`t want to hear about your sex life thankyou so can we keep this thread clean .....:shutup2:
  10. Khufu
    5,704
    31
    aye, its reference to stiffening as opposed to coilovers :)
  11. N8
    17,163
    718
    :ninja::whistle2::moa:
