Sticky cv boots
Ian2012 Feb 12, 2013
  1. Ian2012
    Ian2012 Active Member
    473
    29
    I have just used one of these today on one of my rear outer driveshafts, be interesting to see how long it lasts, the glue didn't like going off in this weather so i helped matters along with a mild setting on my hot air gun, the clips that came with it were interesting, more like a metal cable tie without the little serrations to lcik into just a smooth band. hmmm
  2. aragorn
    18,299
    804
    the smooth band metal ties need a speical tool to do them up afaik.
    A mate of mine used a glue-up boot and found it fell apart inside a few months. When the proper boot is about £15, its bit of a waste of time doing anything else tbh.
  3. Ian2012
    473
    29
    TBH i had had enough of messing around in the freezing cold today so went for quick fix, couldn't face removing suspension bolts
  4. Oranoco
    Oranoco Well-Known Member
    3,913
    391
    They're ok as a temp fix but nothing more.
  5. birch1983
    birch1983 Member
    43
    I tried some prior to Christmas. Both needed replacing last month as they'd split. Re-did them again and now back in the same position. This time round I've bought gearbox oil and intend on swapping that and removing both shafts to replace correctly. I'd never buy these again. Like the man said a little earlier in the thread. Good for a temporary fix, not as a permanent fixture.
  6. Ian2012
    473
    29
    Oddly enough i spotted a few spots of grease on the inside of the wheel today, need to investigate further
  7. birch1983
    birch1983 Member
    43
    That'll be a split. I'm pretty confident too. I spent a few hours making sure mine were fitted properly. Every time they have gone where they are glued.
