Sticking vains in TDI turbo. Should I do a guide? Or has it been convered?
Craig1.8t Feb 13, 2012
  1. Craig1.8t
    Craig1.8t Member
    108
    9
    Just cleaned the insides of a turbo from a 2.0 TDI. Took pictures of the process to do a DIY guide on here, just wondering if someone has already done one or not?
  2. Charlie Ford
    Charlie Ford Member
    96
    i would be very interested in reading this as i seem to be having the issue with turbo-overboost wich i presume is my turbo vains sticking
  3. Craig1.8t
    Craig1.8t Member
    108
    9
    I will do the guide after work then, do you want a quide in removing turbo as well? I'll have to get more pics I have a passat turbo to take off, its the same setup.
    Overboosting will most likely be sticky vains, its common!
  4. Charlie Ford
    Charlie Ford Member
    96
    yeah i have bought the innotech cleaning solution but i need to get the turbo off and i have been told i need to remove it from the bottom? so i need a ramp or a pit to do it.
  5. Sheikh
    Sheikh Member
    654
    20
    I'd appreciate this a lot iswell as i've had overboosting for a while now!
  6. Craig1.8t
    Craig1.8t Member
    108
    9
    all done from underneath, only thing from top is the big plastic turbo inlet pipe, you can leave it on but makes it a little trickier to take turbo off. I haven't got any picture for a guide on taking the turbo off, I can just write it up then get pictures tomorrow. I will make a quide thread after my tea :)
  7. Silky-S3
    Silky-S3 Is loving his new 8V S3!
    1,407
    342
    This would be interesting, do the write up :)
  8. jrsteeve
    jrsteeve Member
    136
    Quick question - is the siren/whistle noise the usual sign of overboost/sticking vains? My car runs absolutely fine but as i'm selling it I could do with resolving the issue so buyers aren't put off!
  9. Craig1.8t
    Craig1.8t Member
    108
    9
    I have just done a guide mate and the car I did the turbo on was solidly stuck vanes, and was whistling really loud. Turbo not fitted back to car yet, so can't answer if the noise has gone or not. But the vanes are perfect now :)
  10. jrsteeve
    jrsteeve Member
    136
    Awesome, looking forward to finding out if it makes a difference.
  11. adamss24
    adamss24 Well-Known Member
    4,578
    402
    Bought Martin's/FJTwelve old audi a6 which had an intermitent power issue for ages, took the turbo apart to clean the vanes and guess what i've found inside ? Do you lot think innotec will clean this ?
  12. kite
    kite Member VCDS Map User
    677
    Hi Chris....Mr Muscle might help...
  13. diffas
    diffas Member
    152
    23
    I opened my turbo too and found also similar metal pieces inside. Do you have any further information about where they are come from or so?
    http://evvk.1g.fi/kuvat/Diudi/random/ahtimessarojuja.jpg - that's what I found.
  14. OhSoFresh
    OhSoFresh Member
    95
    Where is this guide?
