stereo wiring diagram
sherry Jun 25, 2008
  1. sherry
    sherry Member
    181
    Hi guys.
    My a4 came without a stereo and i am now going to fit a new one. Is there a wiring diagram or would anyone know where i can get a harness to fit a JVC KD-AVX33 stereo. This stereo has a smaller plug than the standard jvc harness. Not having much joy finding one so i was just going to wire it myself if i had a diagram.
  2. aragorn
    18,612
    872
    the A4 uses a standard ISO wiring plug for the stereo... although on mine there was no ignition live feed and i had to add one via a relay from the central electrics panel under the dash
    the ISO -> JVC plug lead you can probably find on ebay
  3. NHN
    29,577
    1,779
  4. sherry
    sherry Member
    181
    Thanks guys.
    I have tried fleebay but my stereo takes a smaller connector which i cant find on fleebay.
  5. NHN
    29,577
    1,779
    Post a pic of your connectors so we can see if we can help further, andymac is the man to ask, try asking him for help.
  6. sherry
    sherry Member
    181
    Thanks again m8
    here is a pic of my cars wiring.
    Here is a pic of the connector that goes into my stereo
  7. brendan
    brendan 98 A4 1.8SE
    137
    what's on the other end of that? just bare wires? did you buy the radio new or 2nd hand? i'd be amazed if it came new without ISO connectors somewhere in the box.
  8. NHN
    29,577
    1,779
    No worries, well the top 2 look like standard ISO I think & bottom one is strange as havnt seen that before on an audi, Andymac if you are on here could you help them out?
    If andy isnt on then find him on the ice forum & send him a pm to comment on this thread.
    I'll look about for that connector.
  9. sherry
    sherry Member
    181
    Hi Brendan
    thanks for the reply.
    i bought the stereo brand new. It is a JVC KD-AVX33 and it has bare wires at the other end of the connector.
    Also i got the stereo through ebay and it was imported from Canada or America i think.
  10. NHN
    29,577
    1,779
    well speakers are on the orangey/brown connector so no amp in boot then, all you need are the wiring diags which i believe you can google for & then cut & join, some wires are probably for kline diag to the DIS aswell which wont work I dont think with the JVC anyway, so all you really need is speakers, antenna, ground, live/switched live etc basic wires, maybe illumination wire aswell, but apart from that its fairly simple, I'll try & find the wiring diags for that connector, strange as on my 99 S3 it has the standard connectors so adapter harnesses fitted easily, surely the jvc had a proper plug/socket harness with no?
  11. NHN
    29,577
    1,779
  12. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    The brown connector is indeed the speaker connections but never seen an A4 where all the speakers are wired at the HU. As standard you normally have only the fronts on that connector and then the rears wired to an amp bolted to the left rear speaker.
    Anyway it makes your life a lot easier with all the connections wired.
    You need to buy a male ISO speaker harness, and a male power harness (£2.99 each from Halfords or Maplins). Then connect up as follows:
    Power ISO
    Black wire on Pioneer to brown wire on Audi loom
    Yellow & Red wires on Pioneer to red/blue wire on Audi loom (the one above the brown earth)
    You don't have a switched live on that loom, so you'll have to connect both feeds on the Pioneer to the perm live & rely on turning the HU on/off manually or wire in a switched live from the fusebox. If you do this then the yellow wire goes to perm live and red wire to the new ignition on live.
    Speaker connection:
    The top row is +ve, bottom row -ve.
    The far left pair (top & bottom) are left rears
    The next pair in are left fronts
    The next pair right fronts
    The far right pair (top & bottom) are right rears
    these need to connect to the equivalent white, grey, green & purple/pink wires on the Pioneer.
    I'd solder the connections and use heashrink to insulate them, otherwise you'll have a host of terminal blocks or connectors behind the HU and you're bound to get issues as they will get squashed/tugged when you refit everything.
  13. NHN
    29,577
    1,779
    I told yer, Andy is the man & he would be along any second, lol.
    Dont talk to me about Maplins, god dropped £100 on relays, pcb's etc other day, luckily I dont need it all, but better safe than sorry huh, lol.
    I dont think they have Maplins in Italy so looks like a PO Box forwarding when living in Italy, greatttttttttttt as Tony says.
  14. sherry
    sherry Member
    181
    Thank you so much guys.
    I already have a iso wiring loom that i bought for the stereo but it didnt fit.
    i will cut it and wire it up as andymac describes.
    nigelhobden you where correct m8. Andy is the man :beerchug:
    :hi:
  15. sherry
    sherry Member
    181
    Hi Guys.
    I just thought i would update you with what i have done.
    I carried out anymac's instructions and it work first time :arco:
    Thank you andymac :anbet:
  16. AndyMac
    9,832
    46
    Fast work, nice one!
  17. NHN
    29,577
    1,779
    I was gonna say feck me that was quick.
  18. sherry
    sherry Member
    181
    LOL Cheers guys
    :beerchug:
  19. andybnwc
    andybnwc Member
    752
    did you manage the switched feed ok? did you earth the parking brake feed for image?
  20. aragorn
    18,612
    872
    i created a switched live for mine by taking a feed from the 75X pin on the central electrics and wiring that to the coil of a std 4 pin relay. I powered the main switch of the relay from the normal stereo permenant live feed so its still protected by the normal stereo fuse.
    it all fits nicely behind the stereo
  21. sherry
    sherry Member
    181
    Hi.
    I haven't done the parking brake feed yet. all i did was join the switched feed along with the live just like andymac advised.
  22. andybnwc
    andybnwc Member
    752
    i would defo run down to the bus bar connect ring terminal to the closest terminal to the stereo side, just join the parking brake cable to the black earth cable on your loom
  23. sherry
    sherry Member
    181
    Thank you andybnwc
    would you have any more info on how to do what you recommended?
    I have no idea what the bus bar connect ring terminal is :uhm:
    :beerchug:
  24. andybnwc
    andybnwc Member
    752
    look under the steering column near the row of relays you will see some large terminals some yellow some red with large ring connectors attatched i think its the x75 one on left but just check with a multi meter if unsure! hope this helps
    you have to remove panel under steering column 8mm bolts with clips on top edge, pop of the fuse box cover to se 2 more 8mm bolts
  25. sherry
    sherry Member
    181
    Thank you again andybnwc
    Can i confirm that i join the handbrake cable to the black wire on the loom at the back of the stereo and do i connect the yellow wire with the inline fuse to the ring connector? Should this ring connector be +12v?
    :beerchug:
  26. sherry
    sherry Member
    181
    Hi guys.
    I went out and wired up the stereo as described by andybnwc and it worked first time.
    I didn't realise that there is a big label on the the ring terminals and a yellow one saying X75. LOL it couldn't have been any easier for me.
    Now the stereo goes of with the ignition and i can watch dvd's. Obviously not when driving though :laugh:.
    You guys on this site are the best.
    A BIG thank you again.
    :beerchug:
    :applaus:
  27. andybnwc
    andybnwc Member
    752
    no worries
  28. sherry
    sherry Member
    181
    Another quick question guys.
    i have notticed that i lose my settings such a time ect on my stereo when i turn the car off.
    Is this normal and is there any way to have it so i dont loose them?
  29. Broken Byzan
    13,237
    466
    do you have it wired to a prem live? I had to swap the perm live and ignition live around on my avx1
  30. sherry
    sherry Member
    181
    hi byzan.
    i will give it a try.
    does that mean i will connect my yellow wire that is on to the x75 ring terminal to the black wire on the iso cable of the car and vice versa?
  31. AndyMac
    9,832
    46
    No, just swap the red and yellow cables over
  32. sherry
    sherry Member
    181
    oh.
    i understand now.
    :beerchug:
  33. sherry
    sherry Member
    181
    Got it all done now guys :yahoo:
    Thanks again
    :beerchug:
