Stereo volume problem
Greeny233 Oct 10, 2012
  1. Greeny233
    Greeny233 It's all about the V8. Team V8 Team Silver Audi S4 Audi Avant Owner Group
    1,094
    385
    Well the dreaded happened today, went to turn volume on stereo up and it dropped to 4 instead, is there any fix or do have to replace the head unit like I did in my B5?
  2. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    What head unit do you have?
  3. Greeny233
    1,094
    385
    It's the Audi Symphony.
  4. PetrolDave
    1,559
    85
    Since it's a B6 it's almost certainly a Symphony II and not a Symphony I.
    AFAIK the EEPROM burn out problem doesn't exist in the Series II radios, at least I've never heard anyone else comment about it.
  5. mikeallington
    mikeallington New Member
    Hi, my symphony stereo does the same :( If I put a bit of pressure on the volume knob so that it is at a bit of an angle it works fine.
  6. scottshere
    scottshere Member
    369
    Same here.. Mine goes down when i try turning it up.. I have to pull the button out slightly to get it to go up properly
    Seems like a few people have the same issue..
  7. Krew76
    Krew76 Member
    Mine is the same, i have to do what mike and scott do.
  8. PetrolDave
    1,559
    85
    That's a different issue to what Greeny233 was thinking - where on the Series I radios, as used in the B5, every time you moved the volume control the new setting was written to the EEPROM which as it only has a limited number of writes eventually died.
    Greeny233, no you don't have to replace the head unit like on the B5. But there may be a different problem here with the shaft encoder on the volume control...
  9. Greeny233
    1,094
    385
    thanks for the replies Guys, it's only done it once so far, so fingers crossed it'll be ok until I can afford a double din conversion and a descent aftermarket touch screen/satnav.
  10. tyrrelll
    tyrrelll Lukey.T
    226
    Same thing on my 8p! haha thought it was just me. Starting to drive me mad now
  11. scottshere
    scottshere Member
    369
    Been doing mine in for some time... Wish i could find a cheap battered one on ebay and salvage the volume switch
