Stereo replacement problem
boroian Jun 10, 2011
  1. boroian
    boroian New Member
    Hi,
    I'm having real problems trying to replace my Concert headunit with an aftermarket Sony headunit.
    I've tried the standard harness adapters that are out there on the web but have had not success so far, haven't even got power to the headunit as yet!
    I'm not exactly experienced with this kind of thing, but have managed to fit the same head unit into a BMW which I've just sold for an A4.
    I have a couple of photos here to show the wiring, any advice would be very much appreciated.
    Thanks.
  2. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    Can't see anything with those miniscule pics, but chances are you have a CANBUS Audi (2000+)
    So you don't have the two 12v feeds needed to power the HU, perm live and ignition live
    So you either need to connect the yellow feed from the HU to the red one so that they both go to the perm live on the Audi loom, or you need to wire in an ignition on feed from the fusebox.
  3. boroian
    boroian New Member
    Thanks Andy, not sure what happened with the photos, these should be better.
    My audi is 2004, are you suggesting that I need to patch the yellow wire on the harness into the red wire to get voltage into the head unit?
  4. AndyMac
    9,832
    46
    Yes everything else looks correct
  5. boroian
    boroian New Member
    I've just been and tried this out, success :salute: thanks for the help, much appreciated. Thank you.
