stereo removal keys
vr6gordy Jan 27, 2012
  1. vr6gordy
    vr6gordy Well-Known Member
    2,826
    191
  2. Cadger
    Cadger New Member
    13
    I've got the symphony 2 in mine and used the keys from the first link cant see why they'd change form 02 to 04
  3. vr6gordy
    2,826
    191
    will ive put im in and the keys just pull right back out
  4. Cadger
    Cadger New Member
    13
    put them in and push them outwards towards the side of the car while pulling back at the same time.... quite hard to do (i.e pull the left hand side to the left and back and the right hand side to the right and back)....you sometimes need to just wiggle them about to get them to engage before pulling back its a bit hit and miss I found
  5. vr6gordy
    2,826
    191
    i will give it a go in the morning ... cheers
  6. vr6gordy
    2,826
    191
    well tryied all ways with keys and nothing ... so how the hell will i get it out ???????????????? glove box ??????????
  7. Triquin
    Triquin New Member
    Did you manage to remove your radio as I have a very similar problem with mine?
  8. simon.m
    simon.m Active Member
    2,747
    if you are going to take any thing out to help you id say pull the heater control panel out then you can get your hand up behind it. i have the keys from halfords and as already said still a bit of a pain but i get one side out first then the other it will not just pull out in one go
  9. Cabbyfan
    Cabbyfan Active Member
    840
    34
    You are using 4 keys if it's a double din right ? Also as above sometimes you can push the radio out from behind if you remove the climate module, just be very careful not to scratch the plastic dash trim!
  10. vr6gordy
    2,826
    191
    i managed to fit gateway 100 by removing the glove box... i could see the plug i needed to undo so did it
