Stereo not working properly
Plunky Aug 6, 2009
  1. Plunky
    Plunky Member
    522
    i've just fitted my alpine head unit in my a3, (the headunit has worked perfectly in previous cars) the headunit works ok but i have noticed when the ignition is fully on, the display flashes ever so slightly but does not when the ignition is off but the key is still in the ignition. also i have noticed that the stereo is not holding its memory, i.e. the eq settings do not save when the car is switched off.
    anyone have any ideas whats up with it?
    Liam
  2. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    You just need to swap over the perm live and the "ignition on" live as Audi wire them back to front. So if the Alpine has it's own loom, then chop the red and yellow wires and reconnect the red to yellow and yellow to red, saves chopping the Audi loom.
  3. Plunky
    Plunky Member
    522
    thanks very much mate.. just swapped the wires around and it works perfect! :D
