Stepper/Server Motor Strip
ScottD3 Nov 18, 2013
  1. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,161
    1,121
    As some of you know I like stripping things down see how they work and what it looks like in side and some times I post em up.
    Yesterday I helped my dad fit a new stepper motor to his Touareg cause the old was fault and causing his drive train to clunk and pump going around bends when bumps.
    Easy enough to do, just 5 bolts, 2 plugs and out it comes.
    The strip is really easy as well, 3 torx bolts and it lifts apart.
    Top cover removed showing the motor.
    Pulled the motor/coil out and you see the brushes. Its not very shiny, so assuming that's our issues for this one being faulty.
    End of the motor.
    In side is a set of planetary gears.
    And another set.
    And a third.
    That's it. its very basic.
    I expected a lot more from something that's worth almost £500 and controls the centre diff lock.
    O well.
    That's the inside of a stepper motor or servo motor or gear box motor depending on what you read.
