STEERING WHEEL REMOVAL
ahtcap Mar 15, 2014
  1. ahtcap
    ahtcap Member
    187
    22
    Todays job is fitting cruise control, the only part im unsure of is the removal of the airbag. Not sure if it just pulls off from the steering wheel or if there are clips to release it. Any tips would be appreciated.
    The steering wheel is 3 spoke design (2005 sportback)
  2. NHN
    29,351
    1,720
    Unbolts from rear of wheel, 2 covers to remove 1st.
  3. Mikemc
    Mikemc Scooby Slayer VCDS Map User
    1,024
    37
    as above, remove the airbag bolts, easier to turn the wheel 90 degrees on each side to get at the bolts. after bolts are removed, unplug the battery, then unplug airbag from the split ring, then job done, to remove the actual wheel you need a spline bit like a torx but with more fins on it if thats what there called.
  4. ahtcap
    ahtcap Member
    187
    22
    Removal of the steering cowling (top and bottom) reveals 2 bolts?
  5. fangio
    fangio Well-Known Member
    1,497
    179
    No, the little caps are on the back of the wheel. Turn the wheel 90 degrees and you can see it at the top of the boss, facing the speedo. Prise it out , take out the screw, turn the wheel a half turn and take out the other one. It really is simple!
  6. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    Removing the control box at the base of steering column is tricky. Requires a pin/allen key of the right size to push in a hidden clip.
    Also be sure to NOT turn the clockspring. Tape it up before sliding off the spindle.
    I followed a great how to thread.
    Also coding required in two modules.
  7. ahtcap
    ahtcap Member
    187
    22
    Thanks for all the help, cruise control fitted. But now having issues with it working correctley .won`t resume and set button appears not to be working.
    Any ideas?
  8. MrLapou
    1,233
    121
    Did you code both modules using vcds?
  9. ahtcap
    ahtcap Member
    187
    22
    Yes,had to change one module to 0000042 and the other one to 11463 ,is this correct?
  10. Mikemc
    1,024
    37
    Couldn't tell you unless knew what your car has fitted and the options infront of me
  11. mike foster
    3,967
    If you have a steering module beginning with 1K0 then CC works in the 'alternative mode'. The SET button does nothing.
    To activate pull towards you and down, once activated press upwards to increase speed and downwards to reduce speed. CC will disengage when clutch pedal or brake is pressed. To resume pull towards you again. You can manually disengage by flicking the stalk away from you and de-activate altogether by pushing away as far as possible.
    You need a mid line steering module beginning with 8P0 for the SET button to work.
