Steering wheel removal?
Markb Sep 21, 2005
  1. Markb
    Markb Active Member
    2,139
    As subject how do you go about removing the steering wheel from the A3?
    I've found THIS thread, and as far as I can gather you remove the 2 screws from the air bag and one from the centre, but is that it?
    Oh yeah I'm fitting an S3 steering wheel by the way. Before you get started my A3 one is a bit worn. So I'm fitting an S3 one which I picked up cheap.
    Cheers Mark.
  2. RichA3Turbo
    RichA3Turbo ...Watching you! Moderator
    5,089
    [ QUOTE ]
    Cheers Mark.
    [/ QUOTE ]
    i did exactly the same thing. I fitted an S3 wheels. The airbag is held on by 2 torx screws at the back, that comes off, then you disconnect the airbag connector. Then you need a fat torx head for the centre nut. I had to use a 2'ft breaker bar to undo this is it was ****** tight!! No chance with a regular wrench! Then its just a case of removing old, on with new and reversal of removal
    RIch
  3. Khufu
    Khufu Well-Known Member
    5,704
    31
    i disconnected the battery for 30 mins 1st before i did it.
  4. Markb
    Markb Active Member
    2,139
    So what stops the airbag going off when doing all of the this?
  5. RichA3Turbo
    5,089
    [ QUOTE ]
    [/ QUOTE ]
    Keys not in the ignition. Mine didnt go off and i've disconnected it about 4 times and its oviously not gone off
    Rich
  6. hopper
    hopper Member
    122
    you must be gripping the wheel too much then mark, mine was like new and that was 80,000mile
    as for the airbag, dissconnect the battery and leave it for 10mins to let the charge in the drain
  7. Markb
    Markb Active Member
    2,139
    [ QUOTE ]
    [/ QUOTE ]
    OK so I was after an excuse for replacing a perfectly good wheel LOL As you say mine is still like new, but I was just trying justify it LOL
    Cheers for the air bag advice /ubbthreads/images/graemlins/beerchug.gif
  8. HTC
    HTC Active Member
    3,428
    9
    I wonder if I can keep my wheel and replace ther rest of the car around it for an S3.
    That would be cool. :)
  9. Markb
    Markb Active Member
    2,139
    [ QUOTE ]
    [/ QUOTE ]
    Do I detect a hint of sarcasm there? LOL
  10. HTC
    HTC Active Member
    3,428
    9
    [ QUOTE ]
    [ QUOTE ]
    [/ QUOTE ]
    [/ QUOTE ]
    Naa man, just surealism.
  11. Markb
    Markb Active Member
    2,139
    Right after nearly a year I finally decided to try and fit my S3 steering wheel, but didn't have a spline bit large enough for the central nut /ubbthreads/images/graemlins/frown.gif
    Does anyone know what size bit I need? It's looks like about a 50 Diameter hole with 12 points?
  12. jonS3
    jonS3 Member
    719
    I'd also be interested to know what size the bit required is, as i'm changing mine soon
    cheers
  13. Grant
    Grant Well-Known Member VCDS Map User Audi RS3
    1,206
    118
    The drive bit you need is an M12 spline.
  14. Jaywoo_A3
    Jaywoo_A3 Member Audi A4 Audi Avant Owner Group S-line owners group
    542
    Does anybody have a 3 spoke steering wheel for sale after fitting a S3 one? i want to change mine as its starting to show signs of wear.
  15. the torx in the back are T-30's/ cant remeber the spline head, I just fitted an S3 steering wheel yesterday as well!!!
  16. Markb
    Markb Active Member
    2,139
    Yes I have if you are interested?
  17. Jaywoo_A3
    542
    Yes interested mate do i need a air bag or is it complete? (mine is the SE spec 4 spoke wheel)
  18. I swapped from the SE 4 spoke (yuk) to an S4/S3 effort in my A3 Tdi..... I cant beleive the difference it makes.
    It makes the whole interior fell like a much better place to be.....
    Not sure why but that wheel seems more at home in the A3 than the S4 (dont worry S4 still has s4 wheel!). I ended up paying 150 quid from 4rungs spares for the wheel and airbag and TBH im delighted......but that seems to be the going rate for those wheels.
