Steering wheel airbag delete resistor.
g60leigh Jun 25, 2014
  1. g60leigh
    g60leigh Well-Known Member
    1,674
    207
    Has anyone here removed the standard steering wheel and used a resistor to remove the airbag light and error code?
    If so, what resistor did you use please?
    Or is anyone able to measure the resistance of an oem airbag for me??
    Thanks.
  2. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User quattro Audi A4 Audi Avant Owner Group TDi
    6,201
    2,860
    I wouldn't try measuring the resistance of an airbag if I was you.There is a small chance it will deploy.
    Airbag resistors seem to be anywhere between 2.2 ohm and 10 ohms. I would have thought something like a 4.7 ohm 0.5W resistor would do the job. Maplin stock these if there is one near you.
    The Airbag fault light won't clear until the code is cleared with VAG-COM.
    Karl.
    g60leigh likes this.
  3. g60leigh
    1,674
    207
    Thanks Karl.
    As you day there is so many to choose from. When I have contacted the sellers of the fused versions of these on eBay. The stock reply is to measure the originals air bags resistance.
    I haven't yet swapped over steering wheels so no fault light yet. But I have vcds to clear it if needed.
    I'm wanting to get the resistor ahead of time so I can do the job in one hit.
  4. niallh
    niallh Member VCDS Map User
    213
    Airbag Resistor Guide for VW MKIV R32
    Resistors needed to defeat Airbag Warning Light when removing airbags for motorsport.
    Not recommended if you are going to use your car on the street at all.
    Steering Wheel Airbag resistor is 2 ohm .5 watt
    Seat Airbag resistors needed is 4.7 ohm .5 watt Passenger Airbag resistor needed is 4.7 ohm .5 watt Curtain Airbag resistors needed is 4.7 ohm .5 watt Seat Belt Tensioner resistor needed is 4.7 ohm .5 watt
    To defeat the airbag warning, use a 4.7 ohm 1/2 watt resistor for all airbags. Except the steering wheel where you use a 2 ohm . 5 watt.
    This is from a PDF guide Ive had for a few years now. Worked everytime on my A3
  5. g60leigh
    1,674
    207
    I can't find a 2 ohm. 2.2 seems the closest.
  6. desertstorm
    6,201
    2,860
    2.2 ohm is fine and will work the same.
  7. niallh
    213
    2.2 should be fine. Im sure i got the correct ones from RS components, about 10 for 30p
  8. robin_bga
    robin_bga Member
    50
    Hey niallh, can I please have a copy of that pdf.
    Thanks bro
  9. niallh
    213
    @robin_bga PM me your email and ill send it across
  10. Drue1
    Drue1 Member
    189
    23
    Is there a guide on removing the steering wheel and fitting an aftermarket wheel and where the resistor goes
  11. Drue1
    Drue1 Member
    189
    23
  12. A3jack
    A3jack Member
    107
    10
    Hi, old thread but maybe a silly question but isn't there 3 wires to an airbag and which ones do you put resistor too please? Also it won't have any effect on a multi function wheel will it? Cheers Jack
  13. TGPrince
    TGPrince New Member
    10
    Can anyone confirm which wires to solder the resistor to? Any sort of guide or instructions on how to complete this?
  14. TGPrince
    TGPrince New Member
    10
    Please
  15. TGPrince
    TGPrince New Member
    10
